Old 05-12-2016, 03:39 PM   #1
Overheat
I replace the tank with Pelican 189$ OE supplier and I did a complete system flush after work is done the car is overheated, after 35 mins drive I turn it off, when I checked the tank I saw water in the reservoir tank just go down fast and go up again, after few second I saw no water in the reservoir tank, when I cheker the cap the mechanician didn't fix it well. Now I pup up with the rest of water the mechanician have gave me. I don't what will happen, I don't know if I should drive it again. Do you have an idea guys what to do? Why it overheated after flushing the coolant system? Now I think air get into the system because the resevoir tank was empty after I got home. The guy didn't put enough water??
Thanks for any ideas guys
Hodan is offline   Reply With Quote
Old 05-12-2016, 04:29 PM   #2
It is possible that the system had or now has air in the system. Check the oil to make sure it is not gaining water/mixing. Then search for information on 'bleeding the coolant system'.
Do you speak French natively. If so: Je ne sius pas parle Francias. Some other members here may be able to give you a better answer in Francias.
BFeller is online now   Reply With Quote
Old 05-12-2016, 06:08 PM   #3
Ben-Auto-Design
Ben006's Avatar
I'm french if you feel more comfortable speaking french
Looks like the guy didn't bleed the system at all, on some cars you can just go by filling up the system and let it do the job. But not on the Boxster!
Refill the reservoir and bleed it: Install 3rd Radiator and Coolant System Bleeding Instructions Porsche DIY
Ben
ASE certified Automotive Master Technician.
Porsche Tech in France.
www.benautodesign.fr
Ben-Auto-Design : Performance parts for 9X6 / 9X7
1982 928 S Euro
Ben006 is offline   Reply With Quote
Old 05-13-2016, 03:40 AM   #4
Hi Ben,
Oui je parle francais, j'avais ajouté de l'eau Hier soir apres quelques minutes Le reservoir etait encore vide et il n'ya pas de l'eau qui coule.
Old 05-13-2016, 07:21 AM   #5
Ben-Auto-Design
Ben006's Avatar
Ok, pas de fuite du tout donc?
Aucune fumée quand le moteur tourne?
Le circuit de refroidissement a une capacité de 6 gallons, soit 22 litres, et le reservoir doit faire moins d'un gallon, alors c'est possible qu'il se vide plusieurs fois.
Verifie l'huile avec la jauge pour voir si ça devient pas de la mayonnaise (elle devient clair et pateuse), ce qui indiquerais la presence de liquide de refroidissement dedans.
Si t'as pas de fuite, que ça fume pas blanc, et que l'huile est bonne, alors tu peux continuer a remplir le reservoir jusqu'a ce qu'il arrête de se vider!
Ben
1982 928 S Euro
Old 05-13-2016, 09:11 AM   #6
mikesz's Avatar
I have "burped" my system to remove air bubbles and haven't had a problem. I pull up the metal clip and drive around the neighborhood.
99 Porsche Boxster
Old 05-14-2016, 06:11 AM   #7
Hi Ben, j'ai verifié lhuil du moteur Sa parrait normal, ya pas de fumer blanc. Hier j'ai suivi Un link sur Le forum pour Le bleed, apres je l'ai condui pour 45 mins, apparemment c ok but je vais quand même aller voir Le mechanician qui avait fait la job pour bien enlever l'air definitivement. Hier j'ai acheté Un autre gallon coolant et j'ai mix et il a pris environ 1 1/2. J'ai condui encore c matin pour 45 a 50 mins temperature reste environ 190oc. Et Le reservoir reste rempli.. Je continue a Le suivre.
Merci pour les conseils et très apprecié.
Old 05-14-2016, 06:44 AM   #8
Ben-Auto-Design
Ben006's Avatar
No prob
Si l'huile est bonne et pas de fumée, alors c'etait surement un probleme de purge du systeme, il était pas rempli complétement.
Bonne route!
Ben
1982 928 S Euro
