Thread: Overheat
Old 05-12-2016, 02:39 PM   #1
Hodan
Overheat
I replace the tank with Pelican 189$ OE supplier and I did a complete system flush after work is done the car is overheated, after 35 mins drive I turn it off, when I checked the tank I saw water in the reservoir tank just go down fast and go up again, after few second I saw no water in the reservoir tank, when I cheker the cap the mechanician didn't fix it well. Now I pup up with the rest of water the mechanician have gave me. I don't what will happen, I don't know if I should drive it again. Do you have an idea guys what to do? Why it overheated after flushing the coolant system? Now I think air get into the system because the resevoir tank was empty after I got home. The guy didn't put enough water??
Thanks for any ideas guys
Hodan is offline   Reply With Quote
