Thread: Overheat
Old 05-12-2016, 03:29 PM   #2
BFeller
It is possible that the system had or now has air in the system. Check the oil to make sure it is not gaining water/mixing. Then search for information on 'bleeding the coolant system'.
Do you speak French natively. If so: Je ne sius pas parle Francias. Some other members here may be able to give you a better answer in Francias.
