12-16-2016, 04:38 PM
#41
Yes
Originally Posted by ksjohn
I am curious however if anyone else on this forum has purchased a Z-top?
I am so looking forward to having the Z-top and a new front bumper on my Boxster! I think it is going to look great!
I installed mine 8 years ago I think. Got it from Zeintech in South Africa just before they went bankrupt whew !!!
2001 Base with 2002 3.2 DIY swap 97 "short shift" tip "Joe Toth" aerodynamics, Z top, painted headlights.
2001 Boxster 5 speed
12-16-2016, 04:39 PM
#42
Dang, that's gorgeous, Turbo!
12-17-2016, 02:36 AM
#43
WALDMEISTER
dayum...really great looking cars, guys.
Seems that most owners don't care about the window trim outline on the top (depending on the car color of course, if it is a very dark or black color, it doesn't matter), but tightbox did a really good job there.
01-06-2017, 10:01 AM
#44
I realized that I never posted a link to DRR where I bought my Z-top.
Boxster Hardtops - Home
I am itching to get started on my top, but it is way too damn cold right now. I need to order hinges and a trunk lock loop from Woody. As soon as it warms up, I will be getting it fitted and painted!
01-07-2017, 08:29 PM
#45
Local's
Anyone near Los Angeles have one, installed ?
01-31-2017, 08:53 AM
#46
WALDMEISTER
nope, but can't wait to join the Z-Gruppe soon.......
02-10-2017, 09:33 AM
#47
WALDMEISTER
preparing for Z-Gruppe membership...got mine personally (very nice and helpful contact person btw) delivered today, lucky me
02-10-2017, 07:04 PM
#48
BRAN - lots and lots of pictures and a detailed write-up please of prepping the top and installation. Thanks!
02-11-2017, 02:43 AM
#49
WALDMEISTER
Sure thing!!
The top comes with a 14 page installation manual, side and rear windows and parts.
First impressions:
The roof is much lighter and firmer than I expected (without the windows).
There are minor grooves and chips here and there, but hey, I did not expect German built quality. The roof (most probably) needs to be trimmed alongside the little removable side covers on our cars. A dremel or Nakai-san should be your friend there
Recommendation was: take your time, let the roof sit on your car for a couple of days (btw...optimal conditions are pointing more towards the end of spring with ~20-25°C...lol...I have no heater in my garage, so barely above freezing temperature in there atm...lol), then re-adjust and ALWAYS make sure, that the windshield-roof alignment is perfect throughout the whole adjustment process...so much for the very welcome tips of the seller.
After the step-by-step adjustments are done, grooves/chips/and maybe holes ('cuz you cut away too much) are filled...then sanding, primer and the whole shebang...after that windows, seals, rubber, light and the other shebang
...to be continued
02-15-2017, 11:42 AM
#50
WALDMEISTER
Hey guys,
not quite sure if there are so called "corner rubbers" for the top missing (additional to the seal rubbers)? The manual mentions them.
04-04-2017, 10:01 AM
#51
WALDMEISTER
So I was lucky enough to get a Z-top, just before the distributor for Germany/Netherlands stopped his business. ksjohn, how is yours coming along?
04-04-2017, 10:42 AM
#52
Originally Posted by BRAN
Hey guys,
if you do find any corner rubbers pls let me know as i need two more as well (they are a bit of a wear item).
04-04-2017, 12:32 PM
#53
WALDMEISTER
Sure thing.
Do you have a picture of those you could share?
04-04-2017, 04:18 PM
#54
this guy ...
04-05-2017, 04:28 AM
#55
It does look great on the car
Subscribed.
04-05-2017, 08:53 AM
#56
WALDMEISTER
this guy ...
wow...that corner looks different than mine
so i guess it is not necessary anymore? The provided front rubber seal is pretty thin as well, contrary to the photo
04-05-2017, 09:12 AM
#57
hmmm, seems so. mine is a few generations older than yours. the front seal compresses considerably when fully installed and latched-up.
10-29-2023, 04:49 PM
#58
Yes, I will document the prep and install process and post it here.
Yes, it did come with an installation manual. 14 pgs with text and pictures. Looks OK, but I won't know for sure until I go through the process.
would you be able to send me a copy of the instructions? cheers matty
10-29-2023, 04:53 PM
#59
Sure thing!!
First impressions:
...to be continued
hi mate would you be able to send me a copy of the instructions?
