Old 11-19-2015, 03:37 PM   #1
Replacing tranny fluid
2000 boxster s. I am reading that the lower diagonal brace and metal transmission cover need to be removed. Unless I am reading this incorrectly, the rear sway bar then needs to be lowered. Am I going to screw anything up removing the two bolts attaching pan cover to the aluminum support bars? Will the pan come off and go back on easily with the six bolts removed? Is it really a 1hr job? Anything else I can screw up/ruin besides fluid levels?
Thanks,
David
DWBOX2000 is online now   Reply With Quote
