Old 11-07-2015, 08:00 AM   #21
Some places have a holding tank for you to dump your container into, I doubt he's going to all that trouble to dump it on the ground............
Old 11-07-2015, 08:20 AM   #22
JayG's Avatar
Well here in California, where we actually care about the environment, most oil change places and auto parts store have free oil recycling dump stations
Old 11-07-2015, 05:32 PM   #23
Joe B's Avatar
Originally Posted by tommy583 View Post
The 16QT one i'm talking about has the vent cap on the top if it's standing on end. Check the pic in the first link I posted. (the walmart link).
Yup, that's the one I have. With 15 qts. of oil in it (from my diesel truck, not the Boxster), you don't want to stand it up when the vent cap won't stay closed, unless you don't plan to move it at all. And when you take it to the recycling location, the sloshing oil becomes a black geyser!
Old 11-07-2015, 06:16 PM   #24
I have one of those oil containers that is easier to transport. I pour out of the drain container into that and it enables me to go longer between trips to advance auto parts to recycle. You could pour some into one of those if you're storing.
Old 11-07-2015, 06:43 PM   #25
98 Arctic silver 986
tommy583's Avatar
Ok I get what you are saying. Thankfully the car uses less oil then your truck. I just pour the oil out of the pan back into the jugs after i'm done. So hopefully the vent won't be an issue since I won't be using it for transport.
Old 11-13-2015, 02:44 PM   #26
steved0x's Avatar
I just started an.oil change with the 16 qt square version. The oil drained into the pan fast enough. Maybe because so much sprayed out the sides, it came down and redirected back up by the little fins, probably a quart of oil sprayed outside the boundary of the pan. I will have to try the trick with the pvc pipe because this sucked... Easily the biggest mess I have made in years
Old 11-13-2015, 03:44 PM   #27
tommy583's Avatar
Oh great I'm sure my wife will appreciate the mess I will probably make.
Old 11-13-2015, 04:23 PM   #28
Damn. I just bought the 16 version. Guess I should've kept the receipt.
Old 11-13-2015, 04:27 PM   #29
911monty's Avatar
Because of the volume and especially the rate that the hot oil comes out, I was very concerned of the potential for overflow, especially if you dropped the plug accidentally and restricted the small drain holes in the catch pans. I decided to go with the open top attached from AutoZone. It works very well, even for coolant. Just pour into recycling containers and wipe out.
FloTool/Oil drain 11845 - Read 2 Reviews on FloTool #11845
Old 11-13-2015, 05:11 PM   #30
steved0x's Avatar
This looks like the ticket, if I can find the receipt I am cleaning up my 16 qt square one and returning it, and getting this round one that is linked here.
Has a good spout to.pour back in the bottles for recycling
Has a "reverse" lip around the top so that oil that is moving fast when it hits the edge will get trapped.
Old 11-13-2015, 07:26 PM   #31
tommy583's Avatar
If we can't keep the oil in the pan you just linked.....then we better start paying someone to do our oil changes lol.
Old 11-14-2015, 02:22 AM   #32
Exactly ! I've been using a similar pan for decades. I hate those pan/container combos, just pour it into your container of choice, and there's no need to "wipe dry" the top. The pan I use has a lid, so I just store it in a cabinet "wet", no need to wipe it out.
Old 11-14-2015, 11:44 AM   #33
911monty's Avatar
I like to start with a perfectly clean pan. Once I pour the old oil out I can then inspect the bottom of pan, something that can't be done using the container type pans. Any debris on bottom can then be noted as part of my UOA and filter inspection.
Old 11-16-2015, 06:34 AM   #34
JayG's Avatar
I use a 10 qt pan from Wally world. It had a 8" diameter lid on the top with a removable screen for the oil to drain into. I put it in one of those clear plastic containers for general storage with ~ 6" sides in case of an overflow, etc. The drain cap on the pan may leak a little, a few drips, but since it sits in a container, not an issue
I have not had a problem with getting oil all over the floor or spillage.
Since the M96 holds ~ 9 quarts, 10 quart is fine. . I take the container with the oil pan to a local quick change place that does oil recycling for a free dump. They also take old coolant as well
Old 11-16-2015, 06:21 PM   #35
Joe B's Avatar
That's odd. I've used my square 16 qt. FloTool container twice now, once for my diesel truck and once for my Boxster. I didn't have any oil splashing out around the sides! They sent me replacement vent caps, and so far the one I installed hasn't popped open.
Old 11-18-2015, 05:27 AM   #36
CoBeerToad's Avatar
I usually keep my oil pan full. It usually stays that way until I decide to do the next oil change and then I grab the pan and realize, oh crap, I never dumped it from the last time. Then I promise myself, I will get rid of it quickly this time and then next year, oh crap!
CoBeerToad is offline   Reply With Quote
Old 11-18-2015, 05:38 AM   #37
+ 1 this way you can see if something was on the oil
Old 11-18-2015, 09:24 AM   #38
steved0x's Avatar
I must have had it just in the wrong position. Once the oil started deflecting back up and out I tried sliding it around to different positions and I finally found one that limited the spray. of course by then the oil flow from the car may have just diminished. Fun times
Old 11-18-2015, 04:36 PM   #39
LAP1DOUG's Avatar
This is what I use. I took some spare bulkhead fittings and a valve to make this deep drain pan from a square cat litter container that Publix sells.
After I drain all the oil into it, I place it up on a couple of tires, and let gravity drain the oil through a strainer as it goes into my final disposal jug that I carry off to the local quick lube to dump.
Kippis
986S
991S
Van Diemen RF97
Old 11-20-2015, 10:54 AM   #40
tommy583's Avatar
Well I used the new square 16qt pan the other day. I made a small mess while moving it around trying to make a mess. I found as long as the oil is falling close to the hole it works great. I did cut out some plastic to make the hole a little bigger. As for pouring the old oil back into the jugs, it worked better than every other pan I have tried. I think I am happy with it.
