		|  10-23-2015, 06:32 AM | #1 |
	| Registered User
				What is the correct way to drive through a curve (spirited driving)?
			When I come to an curvy exit ramp for example, do I accelerate going into it? Or midway into it? This is purely for fun to pull some Gs. Wondering what the correct way is.
		|  10-23-2015, 06:39 AM | #2 |
	| Registered User
			I like to roll onto the throttle from 3k rpm entering a sweeper and to have the revs at about 4.5k near the apex then full throttle from there on out
		|  10-23-2015, 07:04 AM | #3 |
	| I am my own mechanic....
			As fast as you can without sliding off.
				__________________'04 Boxster S 50 Jahre 550 Spyder Anniversary Special Edition, 851 of 1953, 6-sp, IMS/RMS, GT Metallic silver, cocoa brown leather SOLD to member Broken Linkage.
 '08 VW Touareg T-3 wife's car
		|  10-23-2015, 10:55 AM | #4 |
	| still plays with cars...
			Shiny side up.But seriously, as long as you don't jump on the brakes during a high G corner, the car will  probably have more grip than you have cojones.
				__________________Six speed 2000 Boxster S
		|  10-23-2015, 11:05 AM | #5 |
	| Registered User
			Flat out.  That's the only way to drive.  Flat out.
				__________________I think I have a Porsche problem...
		|  10-23-2015, 11:33 AM | #6 |
	| Certified Boxster Addict
			Get your braking done before turn-in or trail brake if you know how. Heel and toe if you have to downshift. Corner entry should be at a constant speed and mid-range rpm's. Try not to brake in the middle of the corner as it will upset the balance of the car - better to enter the corner too slow rather than too fast. A late apex always helps corner exit speed. Maintain speed, turn in, let the car roll and feel the suspension set; then throttle steer through mid-corner. Get back on the throttle to accelerate out of the corner and start to unwind the steering wheel as early as possible as you begin corner exit. Don't forget to use the entire width of the lane/road to allow the car to track out (to the extent possible). All the while, be aware of sand, gravel, and other road debris that might affect grip and adjust your line and control inputs accordingly.
That's it. Easy breezy.
If you really want to learn drive well, go to a local trackday and have an instructor ride along with you. You will learn the proper techniques, go faster than you ever could on the street, and have more fun than you ever thought possible.
				__________________1999 996 C2 - sold - bought back - sold for more
		|  10-23-2015, 12:26 PM | #7 |
	| Registered User
			Sign up for an autocross.  It gives you the opportunity to test the limits of your Boxster in a safe environment.  I have PSM (Porsche Stability Management) on my Boxster.  I have run autocrosses with it on and off.  I've learned a lot.  I learned that even with the PSM on I was able to lose control of the car and spin it.  In the owner's manual it states that PSM cannot overcome the law of Physics... they were right.  It is great to have learning lessons in an Autocross environment than on an on ramp.
 You also meet some great folks at the events.
				__________________1995 Porsche C4 Cab
 2016 BMW M2, 6 Speed LBB -  ED 7/2016
 2001 Boxster S  - Original Owner - 30K Miles -SOLD
		|  10-23-2015, 02:01 PM | #8 |
	| Registered User
			As fast as you can with a big grin on your face.:dance:
		|  10-23-2015, 02:20 PM | #9 |
	| Artist, 986S tinkerer
			Go to a PCA DE day(s)! This will answer all your questions. Highly recommended, safe and fun!
www.youtube.com/channel/UCohdrH2xHTklM1thxk0KKOQ? |
		|  10-23-2015, 03:05 PM | #10 |
	| Registered User
			Unless your talking about an exit ramp you are very familiar with, just be safe.  If you're going into a corner you don't know, you can't know the apex, and without that info you won't know when to brake.  Since you won't know when to brake, you won't know when to accelerate.  As said, find a DE when you can.  Working with an experienced instructor will increase your skills and confidence.
				__________________2000 Boxster S
 2010 Volvo XC60
 2011 GMC Denali HD 6.6L (sold)
 2008 Cayenne S (sold)
 1989 Targa (sold)
		|  10-23-2015, 04:12 PM | #11 |
	| Registered User
					Originally Posted by thstone  Get your braking done before turn-in or trail brake if you know how. Heel and toe if you have to downshift. Corner entry should be at a constant speed and mid-range rpm's. Try not to brake in the middle of the corner as it will upset the balance of the car - better to enter the corner too slow rather than too fast. A late apex always helps corner exit speed. Maintain speed, turn in, let the car roll and feel the suspension set; then throttle steer through mid-corner. Get back on the throttle to accelerate out of the corner and start to unwind the steering wheel as early as possible as you begin corner exit. Don't forget to use the entire width of the lane/road to allow the car to track out (to the extent possible). All the while, be aware of sand, gravel, and other road debris that might affect grip and adjust your line and control inputs accordingly.
If you really want to learn drive well, go to a local trackday and have an instructor ride along with you. You will learn the proper techniques, go faster than you ever could on the street, and have more fun than you ever thought possible. |
^^^ this ^^^
				__________________Chris
 '86 944, manual steering, a/c delete, 944Max chip
 '87 951, K27, LBE, Turbo S brakes, Koni Yellows, Weltmeister sway bars / strut brace, LSD, full cage, OMP race seats
 '01 Boxster - Seal Grey / Black / Black, Litronics upgrade / de-ambered
		|  10-23-2015, 04:35 PM | #12 |
	| Registered User
			Watch this video over and over until you get it.https://www.youtube.com/watch?v=aDkdg4VMdyE
				__________________Jäger
 300K Mile Club
		|  10-23-2015, 08:16 PM | #13 |
					Originally Posted by Jager   |
Harry Hogge: What do you know about stock car racing?
Cole Trickle: Well... watched it on television, of course.
Harry Hogge: You've seen it on television?
Cole Trickle: ESPN. The coverage is excellent, you'd be surprised at how much you can pick up.
Harry Hogge: I'm sure I would.
		|  10-23-2015, 09:38 PM | #14 |
	| Registered User
I did a club/dealer-sponsored DE this spring with Porsche instructors (Kees Nierop and Jonathon Urlin) and this is exactly how they taught me to do it. Brake hard before the turn and go in slow, keep about 10% on the throttle through the middle part, and then ease on to full throttle (don't stomp it) on the way out. It took me about half the day to realize that I was trying to maintain too much speed going into the turn and I improved dramatically after that. The part that really stuck with me was how you use the front wheels to steer into the turn and the rear wheels to rotate the car out of it. It feels amazing when it works - major grin factor!
				__________________'99 black 986
		|  10-24-2015, 07:54 AM | #15 |
	| Registered User
			Slow in Fast outAs most say, hard on the brakes just before curve, Shift somewhere at that point. Even throttle through the turn until at some point you get on the throttle to come out. A lot depends on the radius and grading of the road. You may even feel when the car is ready for acceleration out. That acceleration is what changes the balance of the car and makes curves so much fun
				__________________2002 S - old school third pedal
 Seal Grey
		|  10-24-2015, 08:53 AM | #16 |
	| Registered User
					Originally Posted by thstone  Harry Hogge: What do you know about stock car racing? Cole Trickle: Well... watched it on television, of course.
Buy Need for Speed and practice, practice, practice:
https://www.youtube.com/watch?v=oeW_drTwlNI
 300K Mile Club
		|  10-24-2015, 05:36 PM | #17 |
	| Racer Boy
			Be smooth! Smooth on the brakes (squeeze them), smooth steering inputs, smooth on the throttle (again, squeeze it). Abrupt inputs to any control can upset the attitude of the car and complicate things when you are really going quickly.
 Smooth, smooth, smooth!
		|  10-24-2015, 05:42 PM | #18 |
					Originally Posted by Racer Boy  Be smooth! Smooth on the brakes (squeeze them), smooth steering inputs, smooth on the throttle (again, squeeze it). Abrupt inputs to any control can upset the attitude of the car and complicate things when you are really going quickly.
This applies to other things too........
		|  10-24-2015, 06:59 PM | #19 |
	| Registered User
			Exit ramp?
 Don't take those fast until you've had one on one instruction with your local PCA autocross instructor.
 After which you still won't take thise fast. I can count at least one forum member who tore the wheels right of the car after hitting the curbing at speed...if memory serves the damage otherwise didn't look that bad but was bad enough for the insurance company to call it game over.
				__________________GT3 Recaro Seats - Boxster Red
		|  10-25-2015, 08:38 AM | #20 |
	| Registered User
					Originally Posted by BoxsterSteve  Shiny side up.But seriously, as long as you don't jump on the brakes during a high G corner, the car will  probably have more grip than you have cojones.
LOL, this is Exactly what I have found !!!!!   The car has more grip than I have Balls..
	|  Posting Rules |
		You may not post new threads You may not post replies You may not post attachments You may not edit your posts
 |  |  |  All times are GMT -8. The time now is 04:30 AM.
