Old 10-19-2015, 09:51 AM   #1
oc-boxster's Avatar
Oil cooler
I know results may vary but I'm wondering how likely it is for the oil cooler in my boxster to fail and cause intermix issues? Has anyone replaced theirs proactively? I am having my starter and alternator replaced and thought it may be a good time to replace it. My 02 had 117,000 miles. I was at my Indy mechanic the other day and they had the engine out of a 2000 996 with a bad oil cooler it was a mess.
oc-boxster is offline   Reply With Quote
Old 10-19-2015, 09:54 AM   #2
The coolers can fail, but it is not a common occurrence. Fortunately, the cooler is easy to remove and test.
Old 10-19-2015, 12:25 PM   #3
Porsche9's Avatar
I have not seen/heard this being an common issue. You may want to do a search on this site to see if anything comes up.
What's much more likily is that your water pump impeller break due to age and end up blocking a water passages of the cylinder head which can lead to a cracked head and possible intermix of coolant and oil. Water pump replacement should be part of regular maintenance.
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
Old 10-19-2015, 04:31 PM   #4
At the rate my Porsche water pumps fail, "regular maintenance" is right...
More pink dripping off mine.
Old 10-19-2015, 06:13 PM   #5
There Is No Substitute.
rick3000's Avatar
I upgraded mine from the base to the 'S' oil cooler, so I guess you could call that preventative. I have never seen anyone post online about an oil cooler failure, I'm sure it happens, but it's not common. A much more common issue is when broken water pump impeller bits clog the oil cooler, at which point you would want to replace the oil cooler to make sure those bits don't get any farther into the engine. I have my water pump on a 60-75k preventative replacement schedule, just to be safe.
