I have not seen/heard this being an common issue. You may want to do a search on this site to see if anything comes up.
What's much more likily is that your water pump impeller break due to age and end up blocking a water passages of the cylinder head which can lead to a cracked head and possible intermix of coolant and oil. Water pump replacement should be part of regular maintenance.
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
