Old 10-13-2015, 03:56 AM   #1
ScottStu's Avatar
Chassis Reinforcement Plate Bolts
So I just finished doing my second oil change on my Boxster and noticed that the two bolts for the plate are missing. I'm sure they were missing when I bought it and just didn't notice on the first oil change. Anybody know of the size or have two of them to sell?
Scott
ScottStu is offline   Reply With Quote
Old 10-13-2015, 06:08 AM   #2
JayG's Avatar
Do a search for the part on ********************************************.com or down load the parts diagrams (PET) from porsche.com.
Old 10-13-2015, 06:38 AM   #3
If you mean the nuts (8). They are M 10. Diagramm shows 986 2004 model.
Regards
Markus
Old 10-13-2015, 07:00 AM   #4
ScottStu's Avatar
Well now I am going to have to go back under the car, I didn't see any bolt ends showing. Hopefully the old owner didn't brake off the bolts.
Old 10-13-2015, 07:16 AM   #5
JayG's Avatar
just go to your local Porsche dealer, they should have the bolts/nuts. find what you want in PET and it generally says what the size is
Markus identified it as a M10 nut, so you can always go to HomeDepot, Lowes or your local hardware store and buy a few. They look like shoulder nuts, if they don't have them, get nuts and washers.
Of course, if you don't get official Porsche nuts, they won't be coated with virgin unicorn semen
Got to have something special as they are ~$2.50 each from Porsche
Old 10-13-2015, 10:40 AM   #6
hahahahahahaha!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 10-13-2015, 11:19 AM   #7
ScottStu's Avatar
Well, after finding time today (and after running and picking up M10 nuts) I slide under the Boxster and it is definitely a bolt not a nut. Maybe the 98's used bolts, I know the picture shows a nut but its not. I guess another trip to pick up some bolts is in order.
Old 10-13-2015, 12:01 PM   #8
Hi ScottStu,
sorry to hear. 98 cars seems to be different to my 04 car. Did a little research. Think you need M 10 x 1.5 bolts. Hope that helps.
Regards
Markus
Old 10-13-2015, 06:04 PM   #9
ScottStu's Avatar
Thanks Markus, I was going to buy a few different sizes but I'll just start there.
Old 10-13-2015, 06:36 PM   #10
JayG's Avatar
home depot and lowes both sell metric bolts
Old 10-13-2015, 06:39 PM   #11
lkchris's Avatar
The nuts shown in the illustration are shouldered ... something you'll likely not find at Home Depot, etc.
Kent Christensen
Albuquerque
2001 Boxster
2007 GL320 CDI, 2010 CL550
2 BMW motorcycles
Old 10-13-2015, 07:19 PM   #12
JayG's Avatar
they do sell shoulder bolts and nuts at least in the ones near me and in any case you can always use a regular bolt and a washer
Old 10-14-2015, 01:02 PM   #13
Thanks guys! I am missing the same two bolts as the OP on my Spec Boxster.
Old 10-14-2015, 01:07 PM   #14
steved0x's Avatar
Maybe there is no fastener on there before 2000?
Old 10-14-2015, 06:00 PM   #15
Most of the obscure hardware for European cars can be found at McFadden Dale's metric hardware section..!
Old 10-16-2015, 01:41 AM   #16
Buy two 45mm x 10m bolts, recently changed mine
Toplad is offline   Reply With Quote
Old 10-20-2015, 02:33 PM   #17
ScottStu's Avatar
Well, got the correct bolts. Thanks Woody. I always had a little rattle on start-up, its gone now. Makes me wonder if any other bolts and nuts are loose under there? I had a knock in the rear end going over bumps and that seems gone also, I might have to spend my next day off tighten up some stuff.
