Old 07-01-2015, 09:26 PM   #21
1st gear plus parking brake always
Old 07-02-2015, 12:24 AM   #22
PaulDash's Avatar
Depends. On an incline, brake and gear.
If parked at a level parking spot, besides a café, with nice girls in it, on a warm sunny day, I park it with its top down and in neutral so I can turn on the ignition before getting in
Past: 944 NA white '86
Present: 986 black '98
Future: 959
PaulDash is offline   Reply With Quote
Old 07-02-2015, 04:52 AM   #23
I had a few SAABs. I am still programmed to put it in reverse when parking. SAABs only let you remove the key when it's in reverse. Always use the parking brake.
bobbeck is offline   Reply With Quote
Old 07-02-2015, 06:36 AM   #24
Joe B's Avatar
1st gear only, unless on a hill or putting the top up/down. In the winter emergency brakes can freeze here.
Old 07-02-2015, 06:44 AM   #25
kk2002s's Avatar
Always in Gear
I do not use e-brake parking in garage. Sits there many days and brakes tend to stick
Seal Grey
Old 07-02-2015, 07:03 AM   #26
steved0x's Avatar
Parking brake and reverse for me in the garage, when parking outside the house it is usually parking brake and whatever gear I think I will drive off in, either 1 or R.
At the track, gear only and never the parking brake. I coast into my desired parking spot and shut off the engine with no foot brake or parking brake application.
Old 07-02-2015, 08:56 AM   #27
WALDMEISTER
BRAN's Avatar
Always 1st gear
+ e-brake on a hill
In the garage sometimes no gear, no e-brake ... lol
Old 07-02-2015, 09:48 AM   #28
amagalla's Avatar
Just curious. What is the logic for NOT putting the car in gear?
Lapis Blue 03 Boxster S
Old 07-02-2015, 10:31 AM   #29
No reason to.
E-brakes are designed for that purpose. All of the "put it in gear" mania online is passed down from gramps and was valid 50 years ago or with cheap cars. I've heard all of the debate and none of it is convincing, just paranoia.
There's also the potential damage to the trans and engine if you are bumped even slightly by another driver.
If your e-brake isn't holding, fix it. Don't put a band-aid on the issue.
It just isn't necessary, but if it helps you sleep...
Old 07-02-2015, 10:36 AM   #30
CoBeerToad's Avatar
Never in gear. I only use the e-brake in public. No gear or brake when in the garage or storage.
CoBeerToad is offline   Reply With Quote
Old 07-02-2015, 10:45 AM   #31
Luckyed
Luckyed's Avatar
First gear - No E-Brake.
(Florida is flat)
2001 Base 2.7 - Arctic Silver - 5 speed - Comfort Top -
3-4 Stalk OBC Upgrade - Double DIN Head Unit
Luckyed is offline   Reply With Quote
Old 07-02-2015, 11:05 AM   #32
From the Porsche Boxster manual:
When parked, always set the parking brake.
Move the PDK selector lever to ”P“ or the gear-shift lever to reverse or first gear.
On hills also turn the front wheels toward the curb.
I always use E-Brake and second gear.
tomonomics is offline   Reply With Quote
Old 07-02-2015, 11:53 AM   #33
lkchris's Avatar
Think of 1st as "park." Exact same function.
If you have auto box, use park AND parking brake.
Kent Christensen
Albuquerque
2001 Boxster
2007 GL320 CDI, 2010 CL550
2 BMW motorcycles
Old 07-02-2015, 12:47 PM   #34
The only good argument I have heard for using the parking brake only, is that if you leave it in first for example and the car gets hit from the front, the motor can get ruined (timing will be thrown off) because the motor will be turning backwards, which is a no-no.
Why would that be a problem? Doesn't the engine turn backwards when in reverse?
(Sorry, that was from a really old post on another car forum.)
Randy
2002 Boxster Seal Gray Metallic: Desnorkled, Changed ashtray to non-smoker's bin, Removed stickers from sunvisors, Added rear speakers, LED Shifter, Porsche logo on trunk lid, New top with heated glass window, Aspheric Driver's Side Mirror Upgrade, More to come...
randy7601 is offline   Reply With Quote
Old 07-02-2015, 04:27 PM   #35
Squozen's Avatar
Both gear and parking brake. You'd be mad to only use one safety precaution when you have two available.
Squozen is offline   Reply With Quote
Old 07-02-2015, 04:42 PM   #36
Or just crank your wheels toward the curb and not risk your drivetrain.
There are no right or wrong answers, only opinions. Even the "experts" concede this.
Old 07-02-2015, 06:44 PM   #37
E-brake and 1st gear. Always.
Don't be this guy...
I was that guy, several months ago. She only moved about 5 feet before I could get to the brakes.
Only problem was, my Boxster rolled under a passing 'big' truck, and the trucks' tail gate lift frame dragged across the hood and frame. End story. my insurance totaled her, thank God that 'replacement value' has become the norm...
Use your parking brake!!!!!!!!!!!!!!1
mcdandc is offline   Reply With Quote
Old 07-02-2015, 09:01 PM   #38
Pdwight's Avatar
Wow nearly lost that E36 and no telling the damage and injury it could have caused. Strange to watch that same car is my daily driver but in white.....a truly awesome little car.
Old 07-02-2015, 09:01 PM   #39
Perfectlap's Avatar
That's what I do. the risk of a distracted driver plowing into my rear and wrecking the trans seems greater to me than the car rolling away..especially if the wheels are turned to the curb.
BORN: March 2000 - FINLAND
Old 07-03-2015, 06:26 AM   #40
BIGJake111's Avatar
Do you park in gear?
Here is a good question, if you have an auto box, do you use the e brake as well? I find myself using it in any car I drive, just habit.
Something tells me that if I got a 981 pdk I would not use the brake just to spite the fact that it isn't a proper lever haha.
