Old 05-11-2015, 08:26 PM   #1
Plan on spending $2,000 per year on the Boxster for maintenance and repairs. You may not need it all in one year, but other years will definitely catch it up. This assumes that the work will mostly be done by a Porsche independent mechanic. If you can do your own work on the car, then decrease by 30%. If you're going to use a dealer, then increase by 50%.
In my experience, a Boxster is higher in ownership costs than a similar year BMW 3-series, but I am not sure how it compares to a Z4.
Read up on the Boxster intermediate shaft bearing (IMSB) issue. If this has not been replaced in the Boxster you are considering, then you will have to decide if it is worth the cost ($2K) to have it replaced. The Boxster community is split on this issue and only you can decide if you need that peace of mind or can live with it as-is.
Do not buy any Porsche without a PPI! A few minor issues can quickly add up to several thousand in repairs. The PPI will be the best $300 you ever spend. This way you will know exactly what you're getting into.
Old 05-12-2015, 01:17 PM   #2
steved0x's Avatar
I bought my 2000 S a few years ago with 103k miles, now I am up to 117K. I did the IMS bearing before I picked it up. The previous owner had recently done the clutch but elected not to do the bearing. If you combine the bearing replacement with a clutch job, then the cost for the bearing drops considerably, since most of the labor is an overlap with the clutch job (figure maybe $3000 total?) At your mileage you could be getting close to new clutch time.
I agree with the $2000 per year. Mine is running well, but I had a scare recently where I thought I was going to have to do an expensive service to replace variocam chain pads. Luckily it turned out to be a false alarm.
This past weekend I took the car out to Sebring for a combine DE with the Citrus and Suncoast PCA regions and had a blast.
Lap of Sebring in my 2000 Boxster S
I have been loving the car. They are great cars.
Steve
Old 05-12-2015, 06:49 PM   #3
Joe B's Avatar
Not my experience. We have a 2005 BMW 325xi and a 2003 Boxster S. The BMW has a little over 100,000 mi., the Boxster a little under. The BMW has been more expensive to own so far. although we love it too.
Old 05-12-2015, 07:04 PM   #4
Pdwight's Avatar
Strange.....right the opposite here
I have a 1998 E36 and a 2001 S. When I got the E36 it was not running and had been sitting for 2 years in the sun. I had the drivers seat reupholstered and a new headliner installed professionally. I replaced the bad fuel pump ($22) and except for oil changes and 1 set of brake pads in the past 5 years it has been my daily driver.....the Boxster true to form about $2K per year with me doing all the work
PS the E36 151K miles, the 01S is at 72K
