Old 04-01-2015, 05:09 PM   #1
Rob175's Avatar
Headlight assembly removal
I was attempting to remove the headlight assembly on my 98' Boxster (to replace a bulb). I did this once before, a number of years ago, but now I'm having a terrible time. The "wrench" that comes in the tool kit just doesn't appear to fit into the nylon receptical fitting in the car's fender hole. It looks like the kit's hex wrench end is bigger than the nylon female fitting, in the fender so it's not turning it.
So I'm really baffled since I know I once removed the assembly. Any ideas? (the "wrench" in the kit is a two part piece...the wrench portion and a pivoting handle... at first I thought I was using the wrong one, but it's the only one in the kit)
What am I doing wrong? Ideas?.... seems nuts to go to a dealer just to do something I did once before.
Old 04-01-2015, 05:24 PM   #2
98 Arctic silver 986
tommy583's Avatar
You have to pull out the black rubber plug behind the carpet to remove the headlight. The little black flaps have the headlight adjustments behind them. I think this is why you are having a hard time.
Old 04-01-2015, 05:27 PM   #3
My supplied wrench had a crack in it which caused it to spread and lose grip. Use a socket instead and make sure you are turning the right way. It's covered in the owners manual.
Chris
'86 944, manual steering, a/c delete, 944Max chip
'87 951, K27, LBE, Turbo S brakes, Koni Yellows, Weltmeister sway bars / strut brace, LSD, full cage, OMP race seats
'01 Boxster - Seal Grey / Black / Black, Litronics upgrade / de-ambered
crooster is offline   Reply With Quote
Old 04-01-2015, 05:34 PM   #4
Living in the desert.
If you'd stop trying to stick the removal tool in the adjustment NYLON HEX, you'd be fine. You're putting it in the wrong hole, as said above.
Whatever
tonichristi is offline   Reply With Quote
Old 04-01-2015, 05:58 PM   #5
tommy583's Avatar
If you end up using a socket, a 5mm should be the correct size.
Old 04-01-2015, 06:11 PM   #6
I suggest you get a manual.
Old 04-01-2015, 06:57 PM   #7
KevinH1990's Avatar
https://www.youtube.com/watch?v=D65x8G1f6AI
Old 04-02-2015, 05:43 AM   #8
Rob175's Avatar
THANKS GUYS!..... now I really feel "stupid". You all are 100% correct I was using the wrong access hole....dumb, dumb, dumb! I suppose I should stick to waxing, cleaning and detailing....lol. As Dirty Harry said: "A man's got to know his limitations"
Thanks again guys!
R
Old 04-02-2015, 06:14 AM   #9
steved0x's Avatar
We've all started somewhere, the Boxster is the first car I have ever worked on.
Here is a great resource: The 101 Projects for the Boxster by Wayne Dempsey of Pelican Parts, the sponsor for this board:
101 Projects for Your Porsche Boxster
You can download an owner's manual here (and plenty of other places too) if you don't have one:
http://jdmfsm.info/Auto/Other/Porshe/Owners%20Manuals/porsche_boxster_owners_manual_2000.pdf
The Bentley manual for the Boxster is very useful as well and they come up on ebay and on this forum from time to time:
Porsche Boxster, Boxster S Service Manual: 1997-2004: Bentley Publishers: 9780837616452: Amazon.com: Books
Good luck and have fun!
Steve
Old 04-02-2015, 10:53 AM   #10
Rob175's Avatar
Thanks.....and fortunitely, the "wrench" didn't fit and turn the adjusters or Lord knows where my lights would be pointing today!...LOL
Old 04-02-2015, 12:23 PM   #11
tommy583's Avatar
Thanks again guys!
R
Glad we were some help to you
