Old 02-22-2015, 12:28 PM   #1
Porsche man's Avatar
550 Spyder motor
Hi What motor mods give the 550 Spyder the extra HP above the standard 3.2 S ?
Cheers
Porsche man is offline   Reply With Quote
Old 02-22-2015, 03:30 PM   #2
Need For Speed
KRAM36's Avatar
I know a part of it was the air intake box.
See this thread.
987 v 986 Air box
Also take a look at this thread.
http://986forum.com/forums/general-discussions/31693-maf-throttle-body-diameter.html
I've got my 987 air intake box modding done, using the stock MAF house so the computer can read the air flow correctly. If you use the larger MAF house you will need a tune.
I also went with the 76mm 996 Throttle Body and the 997 Distribution T to the Plenums.
Hope to have it all installed in the next couple weeks. Still waiting on some attachment parts to come in.
2003 Boxster S
Old 02-22-2015, 05:12 PM   #3
jsceash's Avatar
987 air box and 90 MM (3-1/2") MAF. The motor internally is the same The exhaust was the same.
Air flow and tuning.
Old 02-22-2015, 08:08 PM   #4
Pdwight's Avatar
How much extra HP did it give or have ?
Old 02-22-2015, 08:54 PM   #5
Chuck W.'s Avatar
The 2004 S SE has 6 extra HP over the 2004 S, up from 258 to 264.
1995 Porsche C4 Cab
Old 02-23-2015, 11:57 AM   #6
woodsman's Avatar
Didn't the 2004 S have the 987 airbox?
Old 02-23-2015, 12:15 PM   #7
Pdwight's Avatar
Well 90mm 987 TB's are easy to come by for $100...if that is all it took for 6 to 8 HP it would be the way to go....but a tune is expensive
Old 02-23-2015, 12:31 PM   #8
I am my own mechanic....
Timco's Avatar
Yes. Mine does.
'08 VW Touareg T-3 wife's car
Old 02-23-2015, 01:34 PM   #9
Perfectlap's Avatar
$100 is better spent towards UD pulley. No tune necessary.
Old 02-23-2015, 01:38 PM   #10
BYprodriver's Avatar
No only the special editions
Old 02-24-2015, 06:46 AM   #11
edc
550 Anniversary
edc's Avatar
I also understand there are some changes to the variable cam timing for the later cars.
