02-06-2015, 10:03 AM
$6 Fix for Plastic Window
How I wish I'd taken a "before" picture, so you could see How awful my rear window was! it say it was milky white like a frosted window, and heavily pitted and stained. Before I spent a lot of money on new plastic or full glass top, I thought I'd try some headlight polish I had.
FYI, this took a LOT of elbow grease, and is a SLOW process. I'm actually still working on it after several days of labor. I've buffed the window countless times and invested maybe as much as 12 hours bent over the rear window. But look at the results, for only a $6 bottle of plastic polish!
02-06-2015, 12:03 PM
I too use head light restorer polishing compound to clean up rub areas on my plastic window
Works great
My window is in great shape but extended down time does chafe it a bit
Seal Grey
02-06-2015, 12:24 PM
12 hours is a lot of elbow grease. Now that it's looking good you will have to do a quick polish every few months to keep it looking decent. Once the window has gotten to this point even after a good cleaning it tends to oxidize pretty quickly.
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
02-06-2015, 12:35 PM
Indeed. I'll be buffing it a couple times before every wash. I still want to take the plastic down further...rather than just maintaining it, I'll be ever pushing for a clearer finish. In time I believe I'll be able to cut the fogginess by another 50-75%.
02-06-2015, 05:17 PM
I had a Guards Red 89 C4, too
02-06-2015, 06:20 PM
Once polished out, keep it protected with Plexus. The rear window on my 2002 looks like new, other than a couple minor scratches.
JGM
2002 Boxster S
1973 911 Green FrankenMeanie
PCA DE Instructor circa '95
02-06-2015, 08:11 PM
+1 on the Plexus, my window is 15 years old.
02-07-2015, 07:03 AM
Another good product
210 Plastic cleaner & polish from Sumner Labs. Inc. Sumner Laboratories Inc - Home Cleared my plastic window up nicely. Biggest trick is squeezing between the seats and reaching around the roll bars while the top is up in order to polish the inside. A lot needs to be cleared on the inside as well as the outside so do not neglect that part. Being short is a boon while doing this job. I have done a few windows for other PCA members at our Spring Breakout event in May.
I imagine an orbital polisher with soft foam pad would work nicely but I did all my work by hand and it didn't take all that long.
AKL
'02, Arctic Silver/Graphite Gray, 2.7, TIP, 2nd cat delete, Charlie Chan muffler,de-ambered, Braille Battery, clear tailights, painted bumperettes, clear third brake light, M030 sway bars, F shock tower braces, clear rear deck, '03 side vents.  15mm spacers fore & aft.
02-09-2015, 10:16 AM
I took a look at their website but they sell (12) 7oz cans to a case with a 3 case minimum order. So I checked out ebay and they have a single 14oz can for $15, but it's from Camco. Label looks the same but I've been fooled from knock offs. Does your can say Camco anywhere on the label?
AKL
02-09-2015, 02:28 PM
No. Sumner Laboratories, Inc. Don't know who or what Camco is. If they are selling 210 plastic cleaner and it is not produced by Sumner then I don't know who makes it or what it is.
My wife bought a can along with some other things for her art supplies. Used for plexiglas polishing and I gave it a try on the Boxster window where I found it works fine. Keep us posted on your effort.
AKL
02-10-2015, 08:59 AM
Can someone share the Plexus product link that someone mentioned above?
Can I buy the Plexus product at local store?
02-10-2015, 09:45 AM
Living in the desert.
Originally Posted by HereIam
I'm sure it's an improvement, but I don't think I would call that a "fix".
It would not pass inspection here.
For 12 hours of labor, I would just replace the top.
Whatever
02-10-2015, 11:39 AM
Plexus works well, but its very expensive (12 bucks for a small can). You can find it at most motorcycle shops.
