Old 01-27-2015, 05:51 PM   #1
I am my own mechanic....
Timco's Avatar
Suspension bits & pieces..
I have a random clunk, slow speeds, uneven surfaces, left rear. Not drive train.
Do drop links get replaced or new bushings? Sway bar bushings typically replaced?
Trailing arms get new joints or new arms?
How long can a Box be on jack stands? 2 weeks? Thinking of doing my clutch finally and want to weld on proper flanges in place of those dumb slip joints on the exhaust besides the rear bushings.
'08 VW Touareg T-3 wife's car
Old 01-27-2015, 06:28 PM   #2
steved0x's Avatar
I have had mine on jackstands for 2 weeks at a time, over Christmas 2013 and earlier this year when doing WP/Thermostat/UDP, with no ill effects. This last time was closer to 3 weeks.
Old 01-28-2015, 12:09 AM   #3
Porsche man's Avatar
Had exactly same problem. Replaced trailing arms and drop links. No more "rattle"
Porsche man is offline   Reply With Quote
Old 02-01-2015, 01:03 PM   #4
Timco's Avatar
So am I right? (All rear end)
The trailing arm / control arm can just get new bushings?
The track arm needs to be replaced because of the ball joint?
Drop links get swapped whole?
Replace sway bar bushings while its removed?
Any other tests or checks to do while the rear is torn apart?
Last edited by Timco; 02-01-2015 at 01:11 PM. Reason: I have an obnoxious clunk in the drivers rear suspension.
Old 02-01-2015, 01:17 PM   #5
woodsman's Avatar
Are the brake flex hoses original?
Old 02-01-2015, 02:34 PM   #6
Timco's Avatar
I'll bet so. Braided! Sweet.
Maybe caliper repaint, but my list is super long now.
Old 02-01-2015, 03:00 PM   #7
All good points about what may be the cause of the noise you're hearing. If your drop links are original, consider repacing those first. The links are not that expensive relative to other suspension components and are very easy to change.
My 2000S developed a clunk up front last winter. With 120K miles on the clock, I figured that I had a bad strut or strut mount. I pulled the wheel and found torn boots on my drop link. I had drop links on hand and replaced them on both sides. Noise gone!
Old 02-01-2015, 03:19 PM   #8
woodsman's Avatar
Braided are not original.
Old 02-02-2015, 01:29 AM   #9
Timco's Avatar
Sorry, I'll upgrade to braided.
I want to go the shotgun route and throw parts everywhere to freshen things up.
T
Old 02-02-2015, 02:13 PM   #10
woodsman's Avatar
T
Ya I got that later in the day...
Old 02-02-2015, 05:04 PM   #11
Need For Speed
KRAM36's Avatar
If you really want to go full tilt on the suspension.
Pelican Parts - European Automotive Parts and Accessories - Porsche • BMW • Mercedes • Volkswagen • Audi • Saab • Volvo • MINI
Once added to cart you can delete things you don't think you need and lower the price and these are TRW parts.
