12-29-2014, 07:45 AM
#1
I actually like the RWB spoiler.... Screw me right?
12-29-2014, 08:29 AM
#2
You will have to balance a large spoiler with some kind of front equivalent in order to maintain handling at speed so add that to the cost and weight you will be adding. Weight robs performance but to each his own. One of the main reasons I like the Boxster design is the smooth rounded lines un- encumbered by "spoilers" etc. I am delighted that the rear 'air dam' comes up only when needed then tucks away out of sight. Just my dos centavos but then I am an old guy and what do I know. Fashion can be a cruel master.....
AKL
'02, Arctic Silver/Graphite Gray, 2.7, TIP, 2nd cat delete, Charlie Chan muffler,de-ambered, Braille Battery, clear tailights, painted bumperettes, clear third brake light, M030 sway bars, F shock tower braces, clear rear deck, '03 side vents.  15mm spacers fore & aft.
#3
12-29-2014, 10:16 AM
#4
Originally Posted by pony13ca
Yes that is along the lines of what I would want. I'm curious if this could be modified to fit onto the top of the OEM blade ? I wounder why it was designed to remove the original and replace it vs. be added to it ?
12-29-2014, 11:00 AM
#5
when Porsche went to the cayman they removed the dam andadded the spoiler lip. the 987 boxster keeps a spoiler similar to the 986. uncertain if the fastback has different airflow characteristics than the roadster, or if the fastback had different aesthetic requirements than the roadster. probably a bit of both.
you can buy the ebay product to convert the 986 to cayman style, or actually use a cayman rear spoiler (required modification of the rear bumper cover as per cheetah). fluid987 make some really nice exaggerated cayman style spoilers, but none that work for the 986:
otherwise, if you want to retain the 986 style spoiler but add a lip to the top of it, there was a product out (by I think a Swedish company) that did something like that but can't find a pic anywhere anymore so most likely no longer available.
edit!!! found it:
http://www.auto-gruppen.se/webshop/styling_eng/produkter/bilstyling-exterior/kjolpaket-kaross/porsche/boxster/vingar.html
Reason: found it!!
12-30-2014, 05:51 AM
#6
[QUOTE= there was a product out (by I think a Swedish company) that did something like that but can't find a pic anywhere anymore so most likely no longer available.
/QUOTE]
That Reiger wing looks like the Gemballa wing
Gemballa USA
Not sure that's sold anymore, either.
-T
12-30-2014, 06:47 AM
#7
That Reiger wing looks pretty cool to me. It looks like the base of it must fill up any gap between the wing and the trunk lid pretty well.
Does anyone have a current link for this? or has this site gone obsolete?
12-30-2014, 07:52 AM
#8
[QUOTE=tomonomics;430025]
Originally Posted by there was a product out (by I think a Swedish company) that did something like that but can't find a pic anywhere anymore so most likely no longer available.
/QUOTE
Gemballa USA
-T
That's a sensible and good looking spoiler. It still works as an air dam and enhances the lines without looking obtrusive. It also looks like it would be an easy install.
Can't get the site link to work in "shop" mode though.
02-18-2015, 08:37 PM
#9
Nine8Six, Are you still thinking of doing a spoiler project? Have any connections for creating a replica of something similar to this? I've been trying to find something that adds a subtle lip when retracted, but still deploys...
/QUOTE
Gemballa USA
-T
12-30-2014, 08:05 AM
#10
Originally Posted by The Radium King
this one allows you to buy the rieger unit (for $1000!!!) but, unless they have an old one sitting around, i bet they'll tell you no longer in stock. there's a seller - 911ava - on ebay that has some leftover gemballa parts and may have an old rear spoiler too.
otherwise, I think particle and nine8six should get us a fluid987/porschemesh style rear spoiler for our cars. simple and adds a lot - very whale/ducktail-ish. if you want to get more complicated, the 996tt or 981 style might be fun. OR, maclaren style - changes orientation based on speed/braking.
12-31-2014, 12:50 PM
#11
Here's an idea, go pick up an OEM spoiler, break out the surfboard foam and the fiberglass and make one. Ya never know, you might have a new business in the works. ;-)
