11-02-2014, 10:14 PM
#1
Motorist & Coffee Drinker
A Little Scoring #2 Rod
As I started to pull the wiring harness off my old engine to put on my replacement, I think I found the problem. Looking in the inspection hole for the #2 rod I can clearly see some scoring on the surface:
I don't think that I'll be rebuilding that one, but it will make a good practice engine for the IMSB and chain guides.
11-03-2014, 02:30 AM
#2
Engine Surgeon
That's a lot of scoring! The rod bearing is melted onto the crankshaft, classic rod bolt breakage, too.
US Patent 8,992,089 &
US Patent 9,416,697
11-03-2014, 03:19 AM
#3
I am my own mechanic....
I'm still thinking wiring harness. I can see it's unplugged, just like you suspected.
If Flex Seal can stop a boat with a screen door for a bottom from sinking, it may just fix this too. Beat that inside part back inside, pour in some Slick-50, and seal that hole. Just like some toothpaste is supposed to re-grow tooth enamel, your engine can self-heal and grow a new rod.
'08 VW Touareg T-3 wife's car
11-03-2014, 04:45 AM
#4
It should buff out with a little elbow grease!
11-03-2014, 06:46 AM
#5
I think you should clean up the edges on the inspection hole. They look a little rough.
11-03-2014, 07:33 AM
#6
Track rat
+1
Downshift over-rev?
11-03-2014, 01:53 PM
#7
You hooked me there. I was thinking "there's an inspection hole? I don't recall seeing that." Then I realized what I was looking at. Day-um.
I was going to joke that you might be able to save that knock sensor but it would appear that even that is a bit beat up.
11-03-2014, 03:16 PM
#8
As a serious comment. The rod are fractured/split the end appears to be semi polished, meaning your rod bolt were coming loose. Was there any knock or other noise before the failure? Just curious.
11-03-2014, 04:27 PM
#9
I'm wondering how far that car traveled with the rod bearing stuck to the crank. That had to sound awful.
Did they just install rear speakers and keep going?
11-03-2014, 04:31 PM
#10
JB Weld should fix it right up!
11-03-2014, 04:32 PM
#11
Porsche M96 oem rod bolts. Accept a substitute!
11-03-2014, 04:33 PM
#12
Unfortunately I don't know any history of the car. I got it as salvage and it already had the problem. I expect that I made it a little bit worse when I ran it twice for about 30 seconds. It actually ran on 5 cylinders until I quit giving it gas. Lots of smoke and an expensive sounding rattle.
I'll post some followup pics here later this week when I open it further. I'm curious about the crank and head.
Timco: I thought about Flex Seal and Slick-50, but I'll probably just spray some triple expanding foam inside to stop things from rattling, then sell it as 'rebuilt' on Craigslist.
