Old 11-02-2014, 09:14 PM   #1
78F350's Avatar
A Little Scoring #2 Rod
As I started to pull the wiring harness off my old engine to put on my replacement, I think I found the problem. Looking in the inspection hole for the #2 rod I can clearly see some scoring on the surface:
I don't think that I'll be rebuilding that one, but it will make a good practice engine for the IMSB and chain guides.
Old 11-03-2014, 01:30 AM   #2
Engine Surgeon
That's a lot of scoring! The rod bearing is melted onto the crankshaft, classic rod bolt breakage, too.
US Patent 8,992,089 &
US Patent 9,416,697
Old 11-03-2014, 02:19 AM   #3
I am my own mechanic....
Timco's Avatar
I'm still thinking wiring harness. I can see it's unplugged, just like you suspected.
If Flex Seal can stop a boat with a screen door for a bottom from sinking, it may just fix this too. Beat that inside part back inside, pour in some Slick-50, and seal that hole. Just like some toothpaste is supposed to re-grow tooth enamel, your engine can self-heal and grow a new rod.
'08 VW Touareg T-3 wife's car
Old 11-03-2014, 03:45 AM   #4
It should buff out with a little elbow grease!
Old 11-03-2014, 05:46 AM   #5
I think you should clean up the edges on the inspection hole. They look a little rough.
Old 11-03-2014, 06:33 AM   #6
Topless's Avatar
+1
Downshift over-rev?
Old 11-03-2014, 12:53 PM   #7
flaps10's Avatar
You hooked me there. I was thinking "there's an inspection hole? I don't recall seeing that." Then I realized what I was looking at. Day-um.
I was going to joke that you might be able to save that knock sensor but it would appear that even that is a bit beat up.
Old 11-03-2014, 02:16 PM   #8
jsceash's Avatar
As a serious comment. The rod are fractured/split the end appears to be semi polished, meaning your rod bolt were coming loose. Was there any knock or other noise before the failure? Just curious.
Old 11-03-2014, 03:27 PM   #9
flaps10's Avatar
I'm wondering how far that car traveled with the rod bearing stuck to the crank. That had to sound awful.
Did they just install rear speakers and keep going?
Old 11-03-2014, 03:31 PM   #10
JB Weld should fix it right up!
Old 11-03-2014, 03:32 PM   #11
BYprodriver's Avatar
Porsche M96 oem rod bolts. Accept a substitute!
Old 11-03-2014, 03:33 PM   #12
78F350's Avatar
Unfortunately I don't know any history of the car. I got it as salvage and it already had the problem. I expect that I made it a little bit worse when I ran it twice for about 30 seconds. It actually ran on 5 cylinders until I quit giving it gas. Lots of smoke and an expensive sounding rattle.
I'll post some followup pics here later this week when I open it further. I'm curious about the crank and head.
Timco: I thought about Flex Seal and Slick-50, but I'll probably just spray some triple expanding foam inside to stop things from rattling, then sell it as 'rebuilt' on Craigslist.
