Old 09-21-2014, 09:21 AM   #1
Window won't go down when opening door
Hi all, my boxster has all of a sudden decided not to lower the drivers side window when opening/closing the door. The manual switch in the cab for the window works the window and the hood auto lowers the window. So looks like the door handle switch is the problem. Does anyone know how to remove the door card trim to get access to the door handle switch?
Fatboy3310 is offline   Reply With Quote
Old 09-21-2014, 09:37 AM   #2
Im guessing the micro switch for that is probably inside the door panel. Pretty good demo on this in Wayne's book and a couple videos on YouTube. A search for the location of the micro switch is probably a good bet as well.
Old 09-21-2014, 09:56 AM   #3
Thanks will have a look in youtube
Old 09-22-2014, 08:18 AM   #4
Dave S.'s Avatar
I used the instructions in the link below to show me how to remove the interior door panel.
Boxster Projects | Power Window Motor Repair
Dave S.
2003 Boxster S
Old 09-22-2014, 10:12 AM   #5
MN 986's Avatar
Check out this thread from when I had the same problem. Good luck!
Door window drops but immediately jumps back up
MN 986 is offline   Reply With Quote
Old 09-23-2014, 07:00 AM   #6
austinkthompson's Avatar
Until you can get it repaired try the comfort function window thing. When you put the key in the door lock, hold the key in the door in the unlock position for a second or two. As long as you hold it the windows will go down as long as you hold the key in the unlock position. Just do the opposite when locking the car and it will roll the windows up.
1999 Boxster Lapis Blue
austinkthompson is offline   Reply With Quote
