Old 09-21-2014, 09:46 AM   #1
Giller's Avatar
Strange radio phenomenon
Okay, searched but have had no luck. Every now and then when listening to CDs,my radio will "crackle and beep" - hard to describe. Almost like it's getting some internal electrical interference (can't be external as it's the cd not the radio). Sounds a bit like morse code coming through. Thoughts? Thanks.
Old 09-21-2014, 09:58 AM   #2
Damn Yankee
TeamOxford's Avatar
Venusians.
Just sayin'..........
TO
Old 09-21-2014, 05:44 PM   #3
cd does the same thing when real hot
nicecar is offline   Reply With Quote
Old 09-22-2014, 07:46 AM   #4
Luckyed
Luckyed's Avatar
I notice the same thing when I first start out, but is seems to dissipate.
(and odd that I only seem to hear it from the right side)
Not enough to bring me to do anything more than get prices on having a double din head unit installed.
For now I will deal with it.
2001 Base 2.7 - Arctic Silver - 5 speed - Comfort Top -
3-4 Stalk OBC Upgrade - Double DIN Head Unit
Luckyed is offline   Reply With Quote
Old 09-22-2014, 06:20 PM   #5
Mine does exactly the same thing after about 20 - 30 minutes of playing time. However it sounds great for the first 30 minutes. Weird as hell.
gmboxster is offline   Reply With Quote
Old 09-22-2014, 06:22 PM   #6
YES !!! When mine heats up the sound quality drops significantly.
Old 09-22-2014, 06:31 PM   #7
KevinH1990's Avatar
One of the common problems with the radios is dirty contacts on the CD door. You might want to try cleaning the contacts to see whether that addresses the problem.
Old 09-23-2014, 05:12 AM   #8
DrCactus's Avatar
I had this same issue - turned out to be because of my Cell phone. Cell phone sends and gets signals and its that what was causing the issue. Try driving out in the country area without your cell phone with you.... see if it still does it.
Old 09-23-2014, 05:46 AM   #9
boxster6354's Avatar
With top down driving the laser does get dirty quicker than a home unit or in a hard top, when I had the OEM HU I had cleaned it a few times a year and resolved the issues.
Here is a link to what I used but if you search I am sure you can find similar or better.
Amazon.com: Discwasher Rd1142 Cd/dvd Laser Lens Cleaners [2-brush; Wet]: Everything Else
boxster6354 is offline   Reply With Quote
Old 09-23-2014, 05:50 AM   #10
Giller's Avatar
I did a bigger google search and this came up a few times. Somehow cell phones can causes interference with the speakers and makes that morse-code like noise. I had assumed that because I was using the CD and not the radio, the interference had to be internal, not external. Thanks Doc!
