Old 08-25-2014, 01:36 PM   #4
seningen's Avatar
Bummer -- there is a release cable behind one of the front tire liners.
Do a google search for it. Someone will have posted instructions.
Might not be the easiest thing to get at, but better
than a wrecking ball.
If you can't get to it without removing your wheel -- and of course the locking lug nut is in your frunk - I have had success with a 24mm deep socket and an appropriate amount of force to pop it on the lug, then remove like any other lug nut.
good luck,
Mike
Originally Posted by Tomkreiner View Post
So, after 6 weeks away on business, etc., I returned to a VERY dead Optima battery in my '02 Boxster.
So dead, that when I connect any power source to the emergency power connector in the fuse block, the horn sounds constantly. After some five minutes, however, it quiets down significantly.
Things I tried: 14 V jump box - fully charged, jumper cables, battery charger, hi amps, low amps, 75 A boost, turning key to unlock, and lock / unlock, turning ignition on. Removing fuses, etc.
After the horn quieted, I left my 2 A battery charger on it for three hours... To no avail. What do I do, any ideas? Without taking a wrecking bar to the hood, I have no idea as to how I can open it to service the battery.
Please let me know what I should do next. --- before having car towed to Dealer$hip.
Thanks in advance...
Drivers: '15 Panamera Hybrid (wife's), ' 01 996 GT2, 00 Boxster S, '96 993 Çab/Tip (wife's)
Race Cars: '75 911 RSR Replica & '99 Spec Boxster
mike@lonestarrpm.com
seningen is offline   Reply With Quote
