Old 07-29-2014, 05:32 PM   #1
INstalled replacement immobilizer; Still won't crank.
2002 Boxster with a water damaged immobilizer....
I had the damaged immobilizer exchanged for a new unit (work done by these guys). Code was matched, and I was told it would be plug & play.
I reinstalled everything, but it still won't crank. I turn the key and...nothing...
The battery has a full charge, and there are no other obvious problems, and I am wondering: Is there something that I should have done, but didn't do that is a normal part of the procedure for reinstalling a new immobilizer? Or is something else going on?
Thanks, as always...
roland3337 is offline   Reply With Quote
