Old 07-28-2014, 01:51 PM   #1
4" RSS pulley belt length?
I bought a 2060mm belt and a 2040mm belt for the 4" pulley install and looking to see if someone could tell me if one of these (or none) will fit on my 2001 boxster non-S with A/C, or if I am way out to lunch on the length.
Thanks for your time
Old 07-28-2014, 06:03 PM   #2
I am my own mechanic....
Timco's Avatar
Took me 4 trips to napa each time bringing 3 belts to the shop. If you had a 3.2 I'd give you the part number.
'08 VW Touareg T-3 wife's car
Old 07-28-2014, 06:20 PM   #3
steved0x's Avatar
The belt is the same so you can share your part number. I thought I saw the length on one of the sites that sells them but I couldn't...
Old 07-28-2014, 06:34 PM   #4
Go to this site, click on the other picture that shows the belt, then either use the photo magnifier or select the larger picture to see the belt that they sell with the RSS UDP - or just call GSR.
RSS Underdrive Pulley - Boxster/Cayman (986/987) , Carrera 911 (996/997)
Old 07-28-2014, 09:49 PM   #5
That's a good idea, thank you.
Old 07-29-2014, 05:14 AM   #6
jsceash's Avatar
4" UDP...2100 belt too short This is a post that says 2075mm length is required for a 4" UDP. The RSS is bigger and takes a 2100mm belt.
Old 07-29-2014, 10:05 AM   #7
steved0x's Avatar
I just bought the RSS pulley with belt so if you haven't sorted this out by the next few days I will post the part # of the belt.
