Old 05-10-2014, 07:12 PM   #1
Surprise in my air filter
I opened up the engine for the first time on my new-to-me Boxster (98, 70k). This car is a bit of a mystery as I don't know much about it, or how it has been serviced. I'm trying to do all the "normal" stuff to get a baseline. That's why I wanted to change the air filter.
Surprise!
Someone has put an aftermarket filter (K&N?) in . The orange hose is a poorly installed gasket that is supposed to go around the intake pipe entering the box.
The air box is open on the top - maybe it seals a bit with the engine cover? I removed the hose clamps and found that you cannot remove the air filter from the box - the filter is too big to get out the top. I think the box would have to be loosened up.
I'm interested in what it would take to go back to the stock configuration. What do you guys think? I can't believe this setup is better than stock.
DG Boxster is offline   Reply With Quote
Old 05-10-2014, 08:02 PM   #2
I guess that you didn't have a PPI done?
You'll have to remove the cold air intake and re-install the stock air box. Do a search as there are several threads that address what parts you'll need. If you use new parts, it can be somewhat expensive.
Old 05-10-2014, 09:44 PM   #3
Tucker2's Avatar
That setup is great. Just fix the seals. You've got something very good....don't worry about going back to stock.
Current: 981 Cayman
Former: '02 BS and '08 C
Tucker2 is offline   Reply With Quote
Old 05-11-2014, 02:59 AM   #4
There are enough engine experts out there with opinions that a K&N or similar knock off air filters allow too much dirt past the filter media into your MAF/engine. And if you tend to over oil the filters the extra oil can contaminate the MAF. Not really sure it can be considered a performance enhancement.
Old 05-11-2014, 03:29 AM   #5
JAAY's Avatar
Put a stock intake back in it. Those intakes are all junk.
Old 05-11-2014, 03:40 AM   #6
kjc2050's Avatar
I work for a filtration company. K&N and the like offer an infinitesimal increase in performance because they are less efficient (that is, less restrictive) than the OE filter. Put the stock intake back on.
Old 05-11-2014, 05:48 AM   #7
Thanks for the help guys. It is either a Fabspeed "V-Flow Air Intake System"
Porsche 986 Boxster V-Flow Air Intake System - Fabspeed Motorsport
or an Evolution "EVO High Flow Intake"
http://www.evoms.com/Porsche_986_High_Flow_Intake_System_EVOMS_p/intk986hf.htm
I'm not yet sure how to tell as they both look very similar. I think it might be the Fabspeed since the housing is metal and the EVO claims to be plastic.
Their dyno data shows a modest increase in power and torque, but mine is missing the gasket on top (and the side gasket isn't good) so I'm sure it is drawing in heated air.
I'll read the threads, but I'm inclined to convert back to stock. We may be moving to a desert-type area and I don't want a less efficient filter.
I wish I'd found this on the Pre-Buy, but it wouldn't have changed anything anyway. The PO was freaking out over the mechanic even touching the car. There were no service records, etc. I knew going in there would be surprises like this.
The worst part is this note on Pelican Parts
NOTE: The 1997-99 Boxster OEM air boxes come equipped with extra resonance chambers and may require that they be removed (or the engine dropped) to remove original unit
If that's true I'll be sticking with this filter box
Old 05-11-2014, 06:35 AM   #8
ELoomis's Avatar
Here is a used stock box. No affiliation.
2001 Porsche Boxster 986 Engine Cold Air Intake Box Mtoor Sensor MAF 61 461 | eBay
ELoomis is offline   Reply With Quote
Old 05-11-2014, 08:00 AM   #9
jsceash's Avatar
Surprise!
The previous owner installed an Agency Power Cold air intake system. The split tubing is vibration dampening and acts as a seal around the MAF Tube. There was supposed to be anther piece around the top, to seal the top to the engine cover. The filter is washable similar to a K&N filter and may be oils to catch dust or not oils if you believe that oiling the filter ruins the MAF sensitivity.
Old 05-11-2014, 08:03 AM   #10
1999 base
Meir's Avatar
I have a stock air box.
It's yours if you want it. Just pay for shipping ($20-$25 I would guess).
