Old 05-11-2014, 07:56 PM   #21
Good catch thanks!
Old 05-11-2014, 10:02 PM   #22
Engine Surgeon
Thanks for the advice guys -it has helped decide to just rebuild the old motor- assuming the damage is limited.
When I showed the oil pan to a local Porsche expert he proclaimed it was debris from a failed IMS. "But it has an LN IMS -fitted less than1 year ago",I whined. He was undeterred by the fact. I asked why a failing IMS would release non magnetic phosphor bronze-like swarf . He breezily suggested I have it flat-bedded to him. I didn't ,I just came here instead.Yes ,I am still looking for a Porsche engine rebuilder in Pasadena/S.California.
Potentially the failing IMSB generated debris that was suspended in the oil. At start up the factory oil filtration system bypasses a huge amount of oil. If that oil has debris suspended in it, then it is delivered to the main and rod bearing. These have an epidermis layer of copper which will appear as bronze in many instances..
So what you could have been seeing was secondary, collateral damage that was created by an underlying condition. Collateral damage is what takes these engines out.
US Patent 8,992,089 &
US Patent 9,416,697
Old 05-12-2014, 07:40 AM   #23
Fortunately the original IMS was perfect ( the P.O. Gave it to me with your tool). Your new ceramic IMS is also perfect.The P.O. fitted your spin on filter and a magnetic drain plug .The filter caught a lot of the rod bearing(?) debris. So I am hoping the collateral damage is minor enough to allow a rebuild.
I am sooo glad the P.O. fitted your filter conversion!
Old 05-12-2014, 07:47 AM   #24
Here is a photo of the inside of Jake's filter can opened up for inspection. The solid bits are soft bearing flakes/debris. At the bottom the 'caramel swirl' in the oil is just fine gold-like particles suspended in the oil.
The drain plug had a big pile of black sludge on it that I speculate was moly of some form.
Old 05-12-2014, 06:44 PM   #25
I did the swap a few years ago. Physically the swap is not that hard. Spacers to lower the engine and transmission (the new Cayman S engine cover might take the spacers place now).
One also needs the Bentley book to see both wiring diagrams. There are some sensors that changed, so wiring changes while relatively simple, are needed. This new engine also has the variable lift solenoids, so those need wired to the DME. I think that maybe a dozen pins needs moved.
Vacuum lines are different. I also installed a IPD manifold so which made it probably even more so.
I used my existing fuel rail, so I had to make some adapters to mount to the new engine.
If I remember right there were two different 7.8 DMEs. I believe that the correct one needed was from a 03-04 Boxster / Cayman. I think the later 7.8 had more memory which gave issues in making the DME, immobolizer, and key to handshake. You will have to tow the car to a dealer so that they can flash these to all match one another.
The car ran, but a new flash was needed by Softronic to make everything correct. They did an awesome job of helping me get it exactly the way that I wanted (like removing ALL e-throttle delays).
I also kept the oil / coolant heat exchanger from my 3.2L since it was larger.
I did all work with the engine and transmission on blocks on the garage floor. That way I could ensure the wire lengths and vacuum lines were all factory looking. I installed the engine and transmission into the car together (requires the car to be lifted very high), but I didn't feel like installing them separately.
2002 Boxster S with 3.4L Variocam-Plus Engine Swap
cheetah is offline   Reply With Quote
Old 05-12-2014, 07:17 PM   #26
Cheetah,
Thank you for your overview of adapting the 3.4l engine to an older Boxster. You clearly did a lot of investigative work and seem remarkably unintimidated by it ! If you had made a detailed build thread or video for it -that would have been very popular.
Old 05-13-2014, 07:47 AM   #27
I contacted Softronic regarding the DME swap mentioned in this thread. The reply I got may be useful to others contemplating this 3.4l swap:
I wrote:"Hi, I am replacing the engine in a 2001 Boxster S 6-speed with the 3.4l engine from an '06 Cayman Tiptronic. The 7.2 to7.8 DME change alarms me Do you have a 'plug&play' unit to magically make the new 3.4l engine function correctly? Including the ABS ?
Thanks."
Reply:
"Sorry no on the ABS as the old system is a 7.2 and the 2006 Cayman uses a 7.8 so the coding is different and other issues like the cluster etc.
Best, Scott"
So back to the rebuild. Thank goodness the engine had the Raby/LN /Pelican spin-on oil filter mod.
Old 05-13-2014, 08:02 AM   #28
Track rat
Topless's Avatar
With so much frag floating around in the oil I would be shopping for a clean 3.2L motor from a dismantler and give it a minor update (IMS and chain tensioners) rather than spend 100 hrs on that one only to have it potentially fail in a short time. Just too much opportunity for unseen issues to bite you later.
YMMV
Old 05-13-2014, 08:18 AM   #29
It will be an interesting test of the merits of the Raby/LN/Pelican filter upgrade.
The engine did not seize. Just rod knock.Or what I speculate was rod knock.
So far there is no bearing debris anywhere but the pan and filter. But it will be a week or two before I have results from further dismantling. The oil was otherwise clear and seemingly recently changed.
If Cheetah/Softronic had a simple 3.4l conversion plan , I would have jumped at that chance because that engine has only 8000 miles,is from a friend, and is $3000. But the
'02 Boxster S/06 Cayman difference and the Tiptronic issue seem too much of an obstacle - for me at least.
If the spin-on filter saved the engine it will be a spectacular endorsement of such an inexpensive(compared to a rebuilt engine) modification.
And just to repeat ,the original 80,000+ IMS was perfect when removed and the LN dual row ceramic replacement is also perfect.No IMS hysteria here.
Old 05-13-2014, 04:16 PM   #30
I know that different years had different ABS systems, but my 02 had no problems or issues with the ABS.
Old 05-13-2014, 05:06 PM   #31
Hey Cheetah,
Wayne's book mentions that the 2002 has a few DME/CAN compatibility advantages compared to my '01. I have no clue if that is a critical difference that made your 02Box/Cayman 3.4l swap a success. And that is the problem - there are lots of unknowns in this swap issue and they are potentially insuperable- or trivial.
For example, if you did exactly the same procedure on my 2001 Boxster S 6-speed but used the $3000/8,000 miles '06 Cayman Tiptonic donor engine I found - would it work like yours did? I can't find anyone in the Boxster community who has done exactly that and shared the knowledge. There are lots of gung-ho generalizations ,but no comprehensive details. By comparison,ask which Miata engines fit which older/younger Miatas and there is a huge amount of comprehensive info. That's a pity because the Boxster project is many times the cost and complexity of the comparable Miata engine swap.
This project we are discussing even stressed Jake Raby!So what hope an over-enthusiastic noob Boxster mechanic like me?
Tags
motor swap 3.4 3.2
