Old 05-09-2014, 05:39 PM   #1
steved0x's Avatar
What would cause a boxstwr to just cut off when driving?
Driving down to Sebring, my boxster just cut off while driving down the highway. No warning lights, no spills, good oil and coolant, and it turns over good when cranking, it just won't start. Any culprits come to mind? Fuel filter is new as of Christmas.
Old 05-09-2014, 05:40 PM   #2
steved0x's Avatar
I do hear some clicking when trying to start. Fuel pump?
Old 05-09-2014, 05:42 PM   #3
steved0x's Avatar
According to the gas I have just under a quarter tank. Maybe it is off?
Old 05-09-2014, 05:44 PM   #4
My gas gauge is off and when I had this happen leaving a parking lot 5 gallons of gas did the trick.
Old 05-09-2014, 06:18 PM   #5
Jager's Avatar
A fairly common problem is the fuel level float sticks, causing the gas level gauge be off a little.
Jäger
300K Mile Club
Old 05-09-2014, 06:48 PM   #6
steved0x's Avatar
I got a little gas, and it cranked right up. Went to a gas station and it only took 11.something gallons to fill. Less than 2 miles later it cut off again... Sigh...
Old 05-09-2014, 06:49 PM   #7
steved0x's Avatar
Maybe the fuel pump or relay heating up, and whn I sat for a little it cooled and let it start maybe?
Old 05-09-2014, 07:03 PM   #8
Registered Boxster abuser
healthservices's Avatar
One of the problems with these car is the fuel pump does not always stay lock down on the bottom of the tank after a pump replacement. Either that, the locking tabs broke, or it was not installed correctly to begin with. So because of this the pump and pick up floats a bit, and becomes uncovered at about 1/4 tank level. Thus the running out of fuel even with gas in the tank.
Old 05-09-2014, 07:06 PM   #9
but I did not read all your posts.
Sounds to me with the new info your pump is dead. brushes in pump worn out and only making contact sometimes....
That is... if its a fuel issue
Old 05-09-2014, 07:25 PM   #10
steved0x's Avatar
I am only 20 mikes from Sebring... In Avon park... Uggg
Old 05-09-2014, 08:05 PM   #11
Try a jumper on the relay. I've never had a bad relay on my boxster, but have had Mercs, Volvos and Saabs do just what you describe because of bad fuel pump relays...most often when the OAT is warm.
shadrach74 is offline   Reply With Quote
Old 05-09-2014, 08:14 PM   #12
Old 05-09-2014, 08:14 PM   #13
steved0x's Avatar
Yeah it is like 90. Was able to crank it again after sitting and get 2-3 mikes down the road before it cut out again ..
Old 05-09-2014, 08:32 PM   #14
steved0x's Avatar
I checked what I think was the fuel relay and it was the same temperature as the rest. Of course it has had time to cool down. I called triple AAA and I am not impressed with their response time...
Old 05-09-2014, 08:53 PM   #15
Crank position sensor is taking a crap.
Old 05-09-2014, 10:30 PM   #16
steved0x's Avatar
Tow truck man brought us to the hotel and pick us up at 2 unless we get it fixed somehow maybe someone will have a hot tip for us
Old 05-09-2014, 10:57 PM   #17
Go get an OBDII reader and see what's going on
Old 05-10-2014, 03:56 AM   #18
steved0x's Avatar
I've got my durametric and a laptop, just need to get it hooked up... And figure out what parameters to check...
Suspects:
Fuel relay
Fuel pump
I just had the sump dropped and put in an ebs baffle. Since that was the recent work are any of three related to that?
I will have it back home tonight and can dig into it next week... Fun
Old 05-10-2014, 06:43 AM   #19
tonycarreon's Avatar
how does it die? sputter/hesitate then die or just off like you turn the key?
Old 05-10-2014, 06:51 AM   #20
Take off one of the hoses going to the throttle body and spray some WD 40 into the throttle body while an assistant cranks the motor. If it sputters, then its definitely the fuel system.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
