Old 05-28-2015, 03:48 PM   #101
Usercpy
ilikeching's Avatar
I finally took the chance when i found a extra set of front headlights in mint condition for a real bargain price, as a backup.
So i did this Project with my old headlights. It went well if u have the right Tools.
The router from Dremel, is a little big and difficult for grinding as the headlight is not plain. I'm happy With the result, so, as for the extra headlight set i have, i will do the same in the future.
Some tips: cover rest of the headlightglas for accidental machine scratches's, don't rush and the result will be fine.
Thanks to Particelwave and other here for the great tip and DIY.
http://www.flickr.com/photos/flickr_ching/
ilikeching is offline   Reply With Quote
Old 05-29-2015, 08:11 AM   #102
Nice!
Yours came out very well! I still have some scratches on mine from the sander (Velcro hooks snuck out a couple times) that I have to clean up.
Now you just have to paint the inner reflector!
CraigM is offline   Reply With Quote
Old 05-29-2015, 11:41 AM   #103
Usercpy
ilikeching's Avatar
Originally Posted by CraigM View Post
Nice!
Thanks, inner reflector? how and where?
Old 05-29-2015, 12:38 PM   #104
It's a bit of a hassle for not a huge impact if it's all you're doing, but I painted mine while I had them apart to install my GT Projectors.
When you take off the headlight lenses (after baking and all), there's a gold-colored shroud in the turn signal area that is held in by a screw. It's gold on our headlights but painted like the rest of the shroud on the true clear headlights. I forgot to take pics of it, but it's very obvious once you have them open.
This is how it looks once it's painted, I went with black BBQ paint like ParticleWave suggested:
Old 05-29-2015, 02:30 PM   #105
Some tips: cover rest of the headlightglas for scratches's, don't rush and the result will be fine.
Nice work!
Turn signal shroud piece, "amber" vs "clear".
Old 05-31-2015, 05:22 PM   #106
This is awesome, very ingenuitive!!
chdavis is offline   Reply With Quote
Old 06-05-2015, 10:40 AM   #107
steved0x's Avatar
Does this look like a de-ambered headlight using this method?
97 98 99 00 01 02 Porsche Boxster Left Driver Head Light 99663106320 | eBay
If so it looks like there might be some money to be made If it sells at this price that is...
Old 06-27-2015, 12:57 PM   #108
Usercpy
ilikeching's Avatar
My owen stove is too small to do the baking
is there another alternative to do? the headlights is about 14-15 yrs.
Old 06-27-2015, 01:33 PM   #109
mavis.d's Avatar
Mine too but just leave the oven door open and use and apron or towel to stop most of the heat escaping. It will take longer and a higher temp. I normally use 140c and twenty minutes just be careful not rest any of the plastics on metal
mavis.d is offline   Reply With Quote
Old 11-01-2015, 01:17 PM   #110
Swhitcomb's Avatar
Finally tackled this today. Been on my to do list for almost 2 years.
Before:
After:
Have to order the corners to finish it. Also going to go buy a 3" polisher and work on them some more. For now though, they are deambered and I am happy. Particlewave makes it look very easy. It wasn't. It's quite a bit of work, and the whole time I kept thinking, I'm going to ruin a very expensive set of headlights. Glad it came out ok, and grateful for Particlewave's excellent and clear directions.
02 Boxster
71 VW Karmann Ghia
71 VW Super Beetle
Swhitcomb is offline   Reply With Quote
Old 11-01-2015, 03:56 PM   #111
Bobiam's Avatar
You did well. Congrats. Now......the silver grills have to go. You could go flat black or a darker gray may be really good (flat if possible).
I chickened out on the deambering and just changed the triangles and side fender lights. I really thought I wouldn't like the result, but actually I'm impressed that it looks pretty good. A Boxster fan may be negative about it, but most folks have no idea what the lights are supposed to look like. It really cut down the amt of amber. Good enough (for me).
2001 Boxster, GT3 console delete, lower stress bar, RoW M030 suspension package, painted bumperettes.
Bobiam is offline   Reply With Quote
Old 11-01-2015, 05:41 PM   #112
Swhitcomb's Avatar
Yes, I fully plan on changing the color of the shield. Might even powder coat it. Not too sure yet. I was really hesitant to attack this project. These headlights aren't cheap, and had I messed them up it would've been costly. I am happy with the result though. Once I paint the shield and polish them out a little more, I'll be even happier.
02 Boxster
71 VW Karmann Ghia
71 VW Super Beetle
Old 11-14-2015, 10:45 AM   #113
Has anybody tackled the triangle corners? Considering sanding them down, cracking them open and painting to match...
[/QUOTE]
Old 11-14-2015, 04:39 PM   #114
Crap...I was sanding the headlights again to clean up some rough spots...and I dropped it. Itty bitty ding, no big deal there, but the whole housing is loose in the headlight assembly. Sigh. I'll deal with it tomorrow.
Old 11-17-2015, 01:28 PM   #115
WALDMEISTER
BRAN's Avatar
As I am preparing a little "clear trim outline" mod on my amber headlights, what clear/uv coating are you guys using?
BRAN is online now   Reply With Quote
Old 11-17-2015, 01:56 PM   #116
Good things have been said about the Sylvania headlight restoration kit that comes with some kind of clear coat final step, haven't personally done it yet because I wanted to clean the lenses up more first.
(Which I just finished - 320 grit through 3000 then cleaner/polish - came out soooo much better.)
Old 12-14-2015, 09:52 AM   #117
mikesz's Avatar
what kind of a plunge router tool did you use?
99 Porsche Boxster
Old 12-14-2015, 11:16 AM   #118
I just used a power sander with 60 grit to start (this was the lowest I could go and actually remove material).
It took a long time...doable, but I would recommend making something like earlier in this thread. Took me a solid day (at least 12 hours) per headlight to sand them down.
Old 02-06-2016, 12:00 PM   #119
geraintthomas's Avatar
I'm hoping that this is possible by sanding by hand with some very high grit sandpaper.
I'm looking to do the projector retrofit but I'm too scared to do it on my current facelift clear headlights. So the plan is to buy some pre-facelift orange lights, install the projectors in them, then sand away the yellow so that they're the same as the facelifts. Then use my current clear corner pieces.
Anyone done this purely by hand yet?
Porsche Boxster S Type 986
Old 02-06-2016, 12:32 PM   #120
Nine8Six's Avatar
Absolutely feasible. Ten different ways to do it I'm sure, by hand/sand paper taking the longest but safest.
If you want look really really cool, look up chemical resistance of lexan 9030 polycarbonate. Recalc to correct dissolving formula and go for it, "dip it". The fastest method
