Old 09-12-2016, 06:11 PM   #1
Froggo's Avatar
Can you do the same process to the triangular corner reflector too ?
2000 Triple Black Boxster S
2017 Subaru Outback Grey
Froggo is offline   Reply With Quote
Old 09-12-2016, 06:38 PM   #2
No. It is orange all the way through.
Old 09-21-2016, 09:30 AM   #3
Does it need to be wet sanded with water, just a lubricant like WD, or just dry?
jbryshun is offline   Reply With Quote
Old 09-21-2016, 09:44 AM   #4
mavis.d's Avatar
I use WD40 with the sanding disks and then water after 180 grit
mavis.d is offline   Reply With Quote
Old 09-21-2016, 01:10 PM   #5
MWS
Best tip I have for hand sanding headlights (I used when sanding "foggy" plastic)...
Start with the most corse grit and sand HORIZONTAL, then step down a grit and sand VERTICAL until the previous horizontal scratches are gone, step down and go vertical, step down go horizontal, etc. The reason I found this so handy is by changing directions you can easily see how much to sand with the finer grit to remove the scratches from the previous.
The other tip I just thought to mention is to avoid the temptation of skipping a grit....200 grit will eventually remove 80 grit scratches, but it will take longer and risk an "uneven" surface. Bottom line, use every grit and change directions after each and progress to the finest grit you can find. The results will be better than "professional" as hand sanding gives better control than any power tool.
Old 10-18-2018, 04:58 AM   #6
I agree with Pedro. Love my amber lens!
springer123 is offline   Reply With Quote
Old 10-18-2018, 05:22 AM   #7
1997 Tip, 2018 Macan
rexcramer's Avatar
Long live the amber.
Old 10-18-2018, 10:56 AM   #8
Awwwww...now there are 3 of you.
Maybe you can start a support group.
You should start your very own "Amber Nutz" thread instead of crapping in this one.
Old 10-18-2018, 12:15 PM   #9
I kinda like the amber turn signal with smoked corner look. Contacted Woody to see if he has any. So, sort of 4ish in the amber camp, kind of??
Old 10-18-2018, 08:00 PM   #10
rexcramer's Avatar
With four members, we may be a recognized protected class and granted special compensation under Federal law? :dance:
Old 10-19-2018, 06:41 AM   #11
I will make five. Where do we apply? And I can keep my day job, right?
"YouTube Certified in Various Specialties"
Old 10-19-2018, 08:31 AM   #12
Keith Newby's Avatar
Well....make it six. Amber rules!
Keith Newby is offline   Reply With Quote
Old 10-19-2018, 11:17 AM   #13
This is what happens to amber headlights in this thread:
Thanks to you guys keeping this thread at the top with your posts, I'm getting lots of requests to de-amber members headlights...thanks a lot.
Old 10-19-2018, 11:29 AM   #14
rexcramer's Avatar
My eyes, my eyes you blasphemer and you're welcome.
Old 10-19-2018, 11:56 AM   #15
In all seriousness, this thread was originally just a proof of concept experiment. I've never done a completed set.
Amber looks great on certain color cars and even modified. Here's a set I built for a member years ago:
Old 10-20-2018, 02:33 AM   #16
That's the same setup you built for me years ago , I kept the amber but added the clear corner lense . I think it looks good on my Arctic Silver . By the way the " Fred's lights " are still going strong as is your installation .
rfuerst911sc is online now   Reply With Quote
Old 10-23-2019, 12:11 AM   #17
I agree. I think people are just drinking the clear kool aid. I have clear lenses I'd like to make Amber. Any recommendations?
Porsche Sugar On Me is offline   Reply With Quote
