Old 11-25-2013, 11:29 PM   #1
Moderator
I think Jaay on the forum did a Cayman 5 speed swap with his 3.4/6 engine. What is your goal?
Old 11-26-2013, 05:54 AM   #2
DIY extremist
black_box's Avatar
you'll need a 2003+ DME to make that engine work. To install the new DME, you'll have to replace the ABS brain, rear brake lines, and HVAC controller, possibly more. Better off to start with a newer car.
"Betty" -- 2000 Boxster S, Triple Black, loaded except PSM (sold to a good home)
"Veronica" -- 2008 Boxster S, Arctic Silver on Blue
"Maleficent" -- 2007 Cayman S, Red and Black, TPC Turbo 3.6L 460 RWHP, H&R RSS Coilover / TPC stage 2 suspension
black_box is offline   Reply With Quote
Old 11-26-2013, 02:22 PM   #3
jsceash's Avatar
I believe you will need a 2007-08 DME the 2008 has the dual lobe Varrio + cam set. The 2003 only has single lobe variable Cams. DME, Harness, Immobiliser, etc.
Old 11-26-2013, 07:58 PM   #4
Tucker2's Avatar
OK...thanks guys. I was just looking for a 'Yeah...I did that in one day with set of spanners and a hammer and no problems....'
So....yeah....no go. :-)
Cheers.
Current: 981 Cayman
Former: '02 BS and '08 C
Tucker2 is offline   Reply With Quote
