Old 08-12-2013, 06:03 PM   #1
Reebuck1
Life expectancy for daul-mass flywheel ?
Does anyone out there know the life expectancy for the Boxster Dual-mass flywheel?
How many miles should you get out of it under normal use? Thanks for your help!
Reebuck1 is offline   Reply With Quote
Old 08-12-2013, 06:36 PM   #2
HammerESQ's Avatar
I've heard people saying that they need to be replaced around 100K. When I did my clutch at 90K I used this procedure (http://www.pelicanparts.com/techarticles/Boxster_Tech/44-TRANS-Clutch/DualFlywheelTechBulletin.pdf) and it checked out okay so I decided to risk it.
HammerESQ is offline   Reply With Quote
Old 08-13-2013, 06:30 AM   #3
Topless's Avatar
It really depends on driving style. Mine was shot at 96K but I didn't notice any driving issues. If you do a lot of standing start clutch dumps or rough shifting you can expect it to die young. A smoothly driven car should go 10 yrs or 100K.
Old 08-13-2013, 10:25 AM   #4
100K miles seems nominal. Mine was long gone at 92K.
Old 08-13-2013, 11:15 AM   #5
Theoretical propagandist
Eric G's Avatar
Mine was completely shot at 90K which means it was probably gone long before that with the previous owner.
Old 08-13-2013, 04:30 PM   #6
dagdisco03's Avatar
How does one know if it's working or not? When it's gone does it make noise, vibrate or are there other tell tail signs? What do you notice with a new one installed on a car with 100K?
2000 Boxster S
dagdisco03 is offline   Reply With Quote
Old 08-13-2013, 04:34 PM   #7
truegearhead's Avatar
Mine has 114,000 miles on it, I changed the clutch at 90K and it seemed fine. I drive the car pretty hard and run a few autocrosses a year. Maybe its shot and I just don't know, its not ratteling and still grabs though. Whats the go to aftermarket option for these things?
2003 911 C2
NASA HPDE Instructor
Old 08-13-2013, 05:02 PM   #8
Topless's Avatar
Test it:
My old one was not making noise and looked ok on the surface but failed the elasticity test. Rather than drop $800 for a shiny new one I found a low mileage takeoff that was within spec for $150.
Old 08-14-2013, 03:52 AM   #9
tolum's Avatar
On my side, prior to change my flywheel, when driving slow (40-50 mph) & I suddenly accelerate at a changing traffic light (red to green) I had a kind of motor or transmission miss for half a second. I finally discovered that the miss was the result of too much play on the dual mass flywheel. Should be 15mm not more. I had much more then that... After changing the flywheel, no more miss and smooth accelerations.
2003 Boxster base
Upgrades so far: 4 Stalks installed,OBC, Cruise Control, Variable wipers, Rear speakers, Alpine CDEHD149BT deck, Alpine MRP-F250 4 ch. amplifier, Blaupunkt THb 200A pre-amplified subwoofer, XM radio integration, 997 shifter, front motor mount, LN Engineering IMS upgrade and much more.
tolum is offline   Reply With Quote
