Old 08-14-2013, 03:52 AM   #9
tolum
tolum's Avatar
On my side, prior to change my flywheel, when driving slow (40-50 mph) & I suddenly accelerate at a changing traffic light (red to green) I had a kind of motor or transmission miss for half a second. I finally discovered that the miss was the result of too much play on the dual mass flywheel. Should be 15mm not more. I had much more then that... After changing the flywheel, no more miss and smooth accelerations.
2003 Boxster base
Upgrades so far: 4 Stalks installed,OBC, Cruise Control, Variable wipers, Rear speakers, Alpine CDEHD149BT deck, Alpine MRP-F250 4 ch. amplifier, Blaupunkt THb 200A pre-amplified subwoofer, XM radio integration, 997 shifter, front motor mount, LN Engineering IMS upgrade and much more.
tolum is offline   Reply With Quote
