Old 07-12-2013, 12:56 AM   #1
More's Avatar
Gearbox Code Numbers.
Apparently Porsche make two different styles of 2.5 Manual Gearbox.
Where would I find the code on mine?
Thanks.
1998 Porsche Boxster 986 Convertible.
More is offline   Reply With Quote
Old 07-12-2013, 08:17 AM   #2
The transmission code is on the label on the underside of the front trunk (next to the engine code):
Transmission decoder:
G8600-00x = 5 speed gearbox for 1997 -1999
G8601-00x = 5 speed gearbox for 2000 - 2004
G8620-00x = 6-speed gearbox S-Models 2000-2004
x is either 1 or 2:
-001 is non-limited slip differential (LSD)
-002 is for the LSD
Tiptronic is A8600 or A86XX
Old 07-12-2013, 08:43 AM   #3
BYprodriver's Avatar
I would say last year for G8600 is 1999 since the gearing changed in 2000 to match the new 2.7 engine. Might be different for ROW.
6-speed was improved mid 2001 with a triple row bearing for the imput shaft, replacing
the previous doublerow bearing to reduce vibration.
Old 07-12-2013, 08:49 AM   #4
Yes, after a little more searching I found a good reference and updated the info above. Thanks!
Old 07-13-2013, 02:10 AM   #5
More's Avatar
x is either 1 or 2:
-002 is for the LSD
I can't find the white sticker, looks like it's been removed and never put back.
I have a 1998 Bosxter so I'm guessing my code would fall under the "G8600-00x = 5 speed gearbox for 1997 -1999" you posted.
Thanks for that mate you just saved me a massive headache I would have had to have the engine removed in order to get to the gearbox a very painful job indeed.
Old 07-13-2013, 04:00 AM   #6
jmd
With the last 3 digits, 00x, does anyone know what 103 means?
jmd is offline   Reply With Quote
Old 11-13-2014, 01:09 AM   #7
More's Avatar
x is either 1 or 2:
-002 is for the LSD
IS THAT THE EARLY MK1 G86.00 GEARBOX ?
