Old 06-01-2013, 01:52 PM   #1
golonaus's Avatar
Sec. air inject. system delete after ROW flash 99/3.4
hi guys
I'm thinking about removing my SAI system from 3.4
got my ECU flashed with ROW program ,so it does not monitor it anyway
my question is
which components I can remove and how to connect rest of the vacuum lines(resonance flapper)
been searching but all i can find are the diagrams of the complete system
my car is 99 with 99 3.4
any help/picks/diagrams will be appreciated
Old 06-01-2013, 09:50 PM   #2
The Radium King's Avatar
you can remove 1, 2, 3, 4 and 5 (first diagram). there are blocking plates and gaskets that replace the two 5's. there are other vacuum lines beyond what is shown in the diagram. keep all of them in place. remove the vacuum line from 3 up to the 't' connector. you can plug it or remove the 't' connector as well (it'll make sense when you see the other vacuum lines). the vacuum tank (6) previously fastened to a bracket on 5; you`ll have to find something else to fasten it to.
Old 06-02-2013, 12:53 PM   #3
golonaus's Avatar
thank you TRK
99611334050
99611314053
are this the part numbers I need?
Old 06-02-2013, 01:07 PM   #4
Can't recall; forgot once I purchased them. Info is available with a search here and on rennlist. Two plates, two gaskets, so should be four part numbers.
Old 06-02-2013, 08:46 PM   #5
golonaus's Avatar
Originally Posted by PhamHjenPG View Post
Tóm c? ngay
M?t quý bÃ**** h?t ho h?t h?i d?n d?n c?nh sát:
- Thua ngÃ****i c?nh sát, ch?ng tôi luôn de do? r?ng ông ?y s? b?n tôi!
Viên si quan c?nh sát tr?c ban di?m tinh tr? l?i:
- Thua quý bÃ**** dáng thuong, bây gi?, chúng tôi chua th? giúp gì du?c cho bÃ****. Nhung bÃ**** c? yên tâm, n?u nhu ông nhÃ**** b?n bÃ**** th?t, chúng tôi s? tóm c? ông ?y ngay sau dó.
thanks
that clears out everything
Old 06-03-2013, 06:42 AM   #6
jaykay's Avatar
How will your car fair on an emissions test after removal of this system?
986 00S
Old 06-03-2013, 09:49 AM   #7
there's more info here:
How to remove charcoal canister and not get CEL?
including part #:
996 113 140 53
996 113 340 50
996 113 233 50
996 113 213 51
good luck without pulling-off the intake (at a minimum will need to pull the two crossover tubes methinks).
Old 06-06-2013, 11:54 AM   #8
golonaus's Avatar
TRK thank U
just got all the parts
I know it will be a challenge
There is not much room
it is very hard to remove just tubes without loosing up intake since I have my engine mounted on stock height
ROW software doesn't monitor SAI and After cat O2
