-   -   Sec. air inject. system delete after ROW flash 99/3.4 (http://986forum.com/forums/boxster-general-discussions/46245-sec-air-inject-system-delete-after-row-flash-99-3-4-a.html)
golonaus 06-01-2013 02:52 PM
hi guys
I'm thinking about removing my SAI system from 3.4
got my ECU flashed with ROW program ,so it does not monitor it anyway
my question is
which components I can remove and how to connect rest of the vacuum lines(resonance flapper)
been searching but all i can find are the diagrams of the complete system
my car is 99 with 99 3.4
any help/picks/diagrams will be appreciated :cheers:
http://forums.rennlist.com/rennforum...n_system_2.jpg
http://forums.rennlist.com/rennforum...ion_system.jpg
The Radium King 06-01-2013 10:50 PM
you can remove 1, 2, 3, 4 and 5 (first diagram). there are blocking plates and gaskets that replace the two 5's. there are other vacuum lines beyond what is shown in the diagram. keep all of them in place. remove the vacuum line from 3 up to the 't' connector. you can plug it or remove the 't' connector as well (it'll make sense when you see the other vacuum lines). the vacuum tank (6) previously fastened to a bracket on 5; you`ll have to find something else to fasten it to.
golonaus 06-02-2013 01:53 PM
thank you TRK
99611334050
99611314053
are this the part numbers I need?
The Radium King 06-02-2013 02:07 PM
Can't recall; forgot once I purchased them. Info is available with a search here and on rennlist. Two plates, two gaskets, so should be four part numbers.
golonaus 06-02-2013 09:46 PM
Originally Posted by PhamHjenPG (Post 345593)
Tóm c? ngay
M?t quý bÃ**** h?t ho h?t h?i d?n d?n c?nh sát:
- Thua ngÃ****i c?nh sát, ch?ng tôi luôn de do? r?ng ông ?y s? b?n tôi!
Viên si quan c?nh sát tr?c ban di?m tinh tr? l?i:
- Thua quý bÃ**** dáng thuong, bây gi?, chúng tôi chua th? giúp gì du?c cho bÃ****. Nhung bÃ**** c? yên tâm, n?u nhu ông nhÃ**** b?n bÃ**** th?t, chúng tôi s? tóm c? ông ?y ngay sau dó.
thanks
that clears out everything
jaykay 06-03-2013 07:42 AM
How will your car fair on an emissions test after removal of this system?
The Radium King 06-03-2013 10:49 AM
there's more info here:
http://986forum.com/forums/boxster-racing-forum/31987-how-remove-charcoal-canister-not-get-cel-2.html
including part #:
996 113 140 53
996 113 340 50
996 113 233 50
996 113 213 51
good luck without pulling-off the intake (at a minimum will need to pull the two crossover tubes methinks).
golonaus 06-06-2013 12:54 PM
TRK thank U
just got all the parts
I know it will be a challenge
There is not much room
it is very hard to remove just tubes without loosing up intake since I have my engine mounted on stock height
ROW software doesn't monitor SAI and After cat O2
