Old 06-01-2013, 09:50 PM   #2
The Radium King
The Radium King's Avatar
you can remove 1, 2, 3, 4 and 5 (first diagram). there are blocking plates and gaskets that replace the two 5's. there are other vacuum lines beyond what is shown in the diagram. keep all of them in place. remove the vacuum line from 3 up to the 't' connector. you can plug it or remove the 't' connector as well (it'll make sense when you see the other vacuum lines). the vacuum tank (6) previously fastened to a bracket on 5; you`ll have to find something else to fasten it to.
