View Poll Results: Do you park in gear?
Yes I park in gear 53 75.71%
No I only use the e-brake 17 24.29%
Voters: 70. You may not vote on this poll
Old 05-24-2013, 06:32 AM   #1
Perfectlap's Avatar
Park in Gear
Do you park your car in gear?
Old 05-24-2013, 06:46 AM   #2
Never during winter hibernation. I roll the car by hand every month to further eliminate flat spots.
Rarely on my weekend drives, unless I am on a major incline, along with the parking brake.
Not in my garages either. Flat as a board. Cars don't move.
Why do you ask, PL??
Old 05-24-2013, 06:47 AM   #3
EssexPorsche's Avatar
Nope! That's why they have parking brakes.
Don't care......was made to care! (my Mum)
EssexPorsche is offline   Reply With Quote
Old 05-24-2013, 07:10 AM   #4
You need a third option, sometimes. I will put it in gear as a backup if parked on an incline.
Old 05-24-2013, 07:22 AM   #5
In Gear
I park in gear, but bring it to neutral before staring the car again.
House72 is offline   Reply With Quote
Old 05-24-2013, 07:31 AM   #6
Keith Newby's Avatar
I always park in gear...just good insurance. However, a friend of my father said to park in second gear rather than first to lessen the possibility of a chipped gear tooth in case someone bumps your car while parking.
Keith Newby is offline   Reply With Quote
Old 05-24-2013, 07:33 AM   #7
kk2002s's Avatar
I typically only park in gear
The Parking brakes can freeze in the winter with wet conditions
In warmer wet weather, they stick because of the minor rusting
On any incline parking, parking brake yes, in gear yes
Level ground In gear yes no parking brake
My mustang GT, in cold weather, was a bear to shift into 2nd until warmed up. I found leaving it parked in 2nd made it a bit easier to shift
Seal Grey
Old 05-24-2013, 08:16 AM   #8
Guys,
If you park in gear assuming its a forward gear, and some body hits the car from the front whilst parked, its not just body work you will be replacing....its tranny as well. Parking brakes have been around for a very very long time. Thats what they are for.
Old 05-24-2013, 08:20 AM   #9
Originally Posted by EssexPorsche View Post
Guys,
I don't think so. I've pushed my car, when in gear (5th), after winter hibernation, just to make sure the engine did not sieze, prior to starting. And to pull a fresh film of oil down. No issues. I don't do this anymore, but did in the past.
Maybe your right. I really don't know. Maybe the difference is pushing the car vs. an abrupt push/bang on the tranny.
Old 05-24-2013, 08:59 AM   #10
Flavour, pushed it forward in 5th I assume.
I'm talk about pushing it in a direction of travel which does not correspond to the gear it's in.
More specifically being aggressively forced in the opposite direction to that of the engaged gear.
Old 05-24-2013, 09:09 AM   #11
Guys,
I hear what you're saying and I had the same concern but I have to say that this is not necessarily so. Car was parked in 1st gear, no parking brake, rear-ended by car going 45-50mph. Car totaled, engine/transmission is fine and being swapped into another car as we speak.
http://986forum.com/forums/general-discussions/43878-ahhh-my-car-hit-bad-today.html
Spec Boxster Build
Old 05-24-2013, 09:12 AM   #12
Perfectlap's Avatar
This has always been my fear as well. I'm hyper vigilant about the gear box in general. I'd rather fix an e-brake or just keep a chock in the trunk or the passenger footwell.
I once had my car towed in NYC ($350). Somebody said to me "Dude you scewed up, you must not have parked it in gear, you made it too easy for them".
My first thought was "good thing I didn't have it in gear with these tow truck clowns."
Old 05-24-2013, 09:42 AM   #13
T-man,
Your car was rear ended and it was in 1st.
I would not expect damage to the tranny.
What I'm saying if you are parked in 1st and the car gets slammed in the front. The car will be forced back...and the tranny will be toast.
Old 05-24-2013, 09:45 AM   #14
T-man,
Ahh! Yes, I went back and re-read your post and I missed that. Sorry.
Old 05-24-2013, 10:47 AM   #15
MK_Hatter's Avatar
I have suffered the dreaded frozen brakes problem on different cars, so I try and park in opposite gear as much as possible.
If someone does end up crashing into me that hard I would not want to drive it again anyway, take the insurance payout and purchase another.
2014 Boxster S GT Silver, Black Full Leather, 20" Classic Carrera Alloys, Sports Seats, Sports Exhaust, Sports Steering Wheel, PASM. TPM, Bose Surround, Ambient Lighting Pack, Front and Rear Park Assist.
1998 Boxster 2.5 Artic Silver/Boxster Red.
MK_Hatter is offline   Reply With Quote
Old 05-24-2013, 11:15 AM   #16
True, in the winter I don't use it on cars with drum-style parking brakes.
Old 05-24-2013, 12:22 PM   #17
Opposed to Subie Burble
Overdrive's Avatar
I don't put the car in gear, just not a habit of mine, and if I started doing it I'd have several instances of forgetting that I did so when I start the car. If I had to park on a steep enough incline I may do so along with the e-brake. Or if I went to a track day of some sort where the brakes are going to be blazing hot when I stop running, I'd put it in gear to park it instead of using the e-brake, but that's about it.
-O/D
IMSR + RMS
Robbins glass window top
Old 11-14-2013, 12:58 PM   #18
Perfectlap's Avatar
Originally Posted by Overdrive View Post
I don't put the car in gear, just not a habit of mine, and if I started doing it I'd have several instances of forgetting that I did so when I start the car..
My mechanic parks in gear, he did me the favor of leaving the car out since I was coming over after they closed. I got into the car when it was pitch dark out, it lurched foward and scratched the front bumper against the bumper of an old Cadillac or something. Not going to buff out but I'm do for a respray
At any rate..
bump..
Old 11-14-2013, 01:06 PM   #19
No, not unless parked on a very steep gradient.
Old 11-14-2013, 05:10 PM   #20
Only park in gear, never use the parking brake. I left the parking brake on a VW that I had put away for the winter in the driveway. The pads rusted to the drums and i had to drag the car to break it loose.
If you put on the parking brake after a track session, the same thing happens.
Parking brakes are worthless, unless you are into drifting, to use it to get the rear end to slide going into a corner.
You will never be able to use it an an emergency to slow the car down significantly. Just don't use it.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
