View Poll Results: Do you park in gear?
Yes I park in gear 53 75.71%
No I only use the e-brake 17 24.29%
Voters: 70. You may not vote on this poll
Old 05-24-2013, 06:32 AM   #1
Perfectlap's Avatar
Park in Gear
Do you park your car in gear?
Old 05-24-2013, 06:46 AM   #2
Never during winter hibernation. I roll the car by hand every month to further eliminate flat spots.
Rarely on my weekend drives, unless I am on a major incline, along with the parking brake.
Not in my garages either. Flat as a board. Cars don't move.
Why do you ask, PL??
Old 05-24-2013, 06:47 AM   #3
EssexPorsche's Avatar
Nope! That's why they have parking brakes.
Don't care......was made to care! (my Mum)
EssexPorsche is offline   Reply With Quote
Old 05-24-2013, 07:10 AM   #4
You need a third option, sometimes. I will put it in gear as a backup if parked on an incline.
Old 05-24-2013, 07:22 AM   #5
In Gear
I park in gear, but bring it to neutral before staring the car again.
House72 is offline   Reply With Quote
Old 05-24-2013, 07:33 AM   #6
kk2002s's Avatar
I typically only park in gear
The Parking brakes can freeze in the winter with wet conditions
In warmer wet weather, they stick because of the minor rusting
On any incline parking, parking brake yes, in gear yes
Level ground In gear yes no parking brake
My mustang GT, in cold weather, was a bear to shift into 2nd until warmed up. I found leaving it parked in 2nd made it a bit easier to shift
Seal Grey
Old 05-24-2013, 07:31 AM   #7
Keith Newby's Avatar
I always park in gear...just good insurance. However, a friend of my father said to park in second gear rather than first to lessen the possibility of a chipped gear tooth in case someone bumps your car while parking.
Keith Newby is offline   Reply With Quote
Old 05-24-2013, 12:22 PM   #8
Opposed to Subie Burble
Overdrive's Avatar
I don't put the car in gear, just not a habit of mine, and if I started doing it I'd have several instances of forgetting that I did so when I start the car. If I had to park on a steep enough incline I may do so along with the e-brake. Or if I went to a track day of some sort where the brakes are going to be blazing hot when I stop running, I'd put it in gear to park it instead of using the e-brake, but that's about it.
-O/D
IMSR + RMS
Robbins glass window top
Old 11-14-2013, 12:58 PM   #9
Perfectlap's Avatar
Originally Posted by Overdrive View Post
I don't put the car in gear, just not a habit of mine, and if I started doing it I'd have several instances of forgetting that I did so when I start the car..
My mechanic parks in gear, he did me the favor of leaving the car out since I was coming over after they closed. I got into the car when it was pitch dark out, it lurched foward and scratched the front bumper against the bumper of an old Cadillac or something. Not going to buff out but I'm do for a respray
At any rate..
bump..
Old 11-14-2013, 01:06 PM   #10
No, not unless parked on a very steep gradient.
Old 11-14-2013, 05:10 PM   #11
Only park in gear, never use the parking brake. I left the parking brake on a VW that I had put away for the winter in the driveway. The pads rusted to the drums and i had to drag the car to break it loose.
If you put on the parking brake after a track session, the same thing happens.
Parking brakes are worthless, unless you are into drifting, to use it to get the rear end to slide going into a corner.
You will never be able to use it an an emergency to slow the car down significantly. Just don't use it.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 11-14-2013, 05:50 PM   #12
jsceash's Avatar
I park in gear, And only really use the e-brake if the engine is running and setting. Say warming up in the driveway or garage
Old 11-14-2013, 10:01 PM   #13
RawleyD's Avatar
That's why they are not called Emergency brakes anymore.. they are Parking brakes
:ah:
Old 11-14-2013, 09:39 PM   #14
Bmod986's Avatar
Im going to be honest with you guys my hand brake is broken/ I have to tighten it or replace cable if it is stretched. But regardless I still park in gear always have and I still put up the hand brake. My friends have asked me why I use the hand brake if it doesn't work, I just do it out of reflex.
Bmod986 is offline   Reply With Quote
Old 11-14-2013, 09:53 PM   #15
I use the parking brake for parking...no explanation needed
Seriously, though. Parking brakes were made for that and have never failed me. Parking in gear seems odd to me, but I do also crank the wheel toward the curb just in case the parking brake has a failure.
Old 11-15-2013, 12:05 AM   #16
Just answering the question here and not saying it is right or wrong, but I have been parking in gear for 24 years.
What I notice more with mechanics/body shops/dealer cars that they leave the gear in and the parking brake off all the time.
02 Boxster (DD sans kids)
08 Corvette Z06 (Track car)
Old 11-15-2013, 02:55 AM   #17
gregdacat's Avatar
I have always owned cars with manual transmissions and back in the day would only use the parking brake. Then I owned an '86 Chev Celebrity with a 4 speed manual that had a nasty habit of rolling away when parked. Took it to the dealer several times and they could never get the parking brake to hold by itself. I have been leaving my cars in gear, along with the parking brake ever since.
Greg
2002 Triple Black, Desnorkled, Bumper Plugs, LN IMSB Upgrade
gregdacat is offline   Reply With Quote
Old 11-15-2013, 03:20 AM   #18
I am my own mechanic....
Timco's Avatar
Dad always drove a stick. Always.
Taught me to put it in gear. 2nd. Always have. I've had 2 friends with vehicles that rolled back on small inclines. One was slowly making a get away maybe 200' down the drive and into the road. Someone knocked on his door.
BUT, this is my (and my or my wife's entire family) first Porsche so I'm open to learning.
'08 VW Touareg T-3 wife's car
