05-26-2017, 04:30 PM
#521
Originally Posted by Pepemcgill
Hi Mr. Heiko,
I would be grateful if you could help provide code for becker type 4462, serial number 25010654
Thank You,
Peter
8305 should be the correct code for your radio :-)
Heiko
https://greatcyclechallenge.ca/Riders/HeikoVoss
Previously owned:
05-27-2017, 01:28 PM
#522
Mr Heiko,
If you could be so kind as to provide me with a code for...
CDR 220
Model BE 4462
SN: X5038407
Thank you for your efforts...
Geoff
05-28-2017, 07:04 PM
#523
Originally Posted by gpope
Mr Heiko,
CDR 220
Model BE 4462
SN: X5038407
Geoff
Hey Mr Geoff;
Try 3497 1st and if that doesn't work try 3496 next.... this is another one of those
inbetween numbers, hopefully it will work.
I will be in your neck of the woods on Thursday on the way to the cottage in Sprucehead ME and then back down to Stoughton MA for a few days after that.
I'm actually doing the first part of my June Cancer ride Miles in Mass and Maine :-)
while on vacation
Cheers
Heiko
Previously owned:
05-28-2017, 08:15 PM
#524
New page and a reminder....
To all of you that are getting codes from Heiko...... be sure to check out the below link. Anything helps. And, he is so close to his goal for such a great cause. Come on folks.... PayPal $5 or $10 for a code!
1995 Porsche C4 Cab
06-03-2017, 04:09 AM
#525
Hello !
My CR-22 serial is: BE 4367 Y5022257
Can you help me ? What is the radio code ?
Thanks.
06-03-2017, 05:43 AM
#526
Can I please get the code to my radio?
Vin: wp0ca2980vs625752
Please email it to me - porsche27@live.ca
Thx
06-03-2017, 07:03 AM
#527
Originally Posted by manu_ac
Hello !
Thanks.
try 2429 first and if that doesn't work try 2428
Heiko
Previously owned:
06-11-2017, 09:08 AM
#528
S O S can i play too
cdr220 be4462 w5009739
06-12-2017, 05:40 PM
#529
try 2115 first and if that doesn't work try 1115
Heiko
Previously owned:
06-13-2017, 05:27 AM
#530
awesome, thanks
06-13-2017, 07:51 AM
#531
am i supposed to do anything other than just punch in these codes where the stars are? these put me in wait mode.
06-13-2017, 08:02 AM
#532
It should just run after entering the 4th digit.... if it goes into wait mode you've exceeded the amount of retries with the wrong code.
More times than not I've seen the display have issues and show wrong serial numbers.... I hope the serial w5009739 is the correct serial.... in which case the codes should work....
H
Previously owned:
06-13-2017, 09:25 AM
#533
i couldn't get the display to give me the serial # i had to pull the stereo, it was stamped in the casing. does that make a difference?
06-14-2017, 05:05 AM
#534
As long as the logic board in the unit is still the original board its fine, but if that unit had a board replaced at one point the serial number will be different.
If you need the instructions again to retrieve the serial number here they are... it should work fine...
Turn off radio.
Hold down the TP button for at least 10 seconds.
Turn the radio on. "Becker 1" will be displayed.
Rotate the right knob slowly, as it will display the Becker model number.
Rotate again and radio serial number will display on radio display.
Heiko
Previously owned:
06-14-2017, 09:46 AM
#535
ok i followed your instructions and got the code,it is w5009739. do i have any other options? or am i stereo shopping? i really appreciate the help, thanks.
06-14-2017, 11:12 AM
#536
2115 is what I get on my side for a 1st option code...
2nd option is 1115 and 3rd option is 2111 which I have never had to use.
The various options are usually due to a revision change in the model # which
uses a variant of the original algorithm. This has only happened to me a few times where the code doesn't work...
You could try calling the dealer and see if they have it on file, either something
is wrong with the unit accepting the code or the variant of the code isn't supported
for that serial number :-(
Heiko
Previously owned:
06-19-2017, 05:34 PM
#537
Hello there,
Recently had to reset my radio due to a dead battery. 2002 Porsche Boxster S.
Type: 4362
Serial Number: 15003536
Any ideas of a radio code that might work for me? All help is greatly appreciated
H has been remarkable in this thread, and I'm hoping he can help me as well.
06-20-2017, 05:51 AM
#538
Originally Posted by bmanning41
Hello there,
Type: 4362
try 9808 first and if that doesn't work try 8806
Heiko
Previously owned:
06-20-2017, 08:21 AM
#539
Code
As everyone else.
Type: 4462
Serial: X5021729
CDR-220 Radio
If I could get a code that would be awesome. Thanks a lot,
CR
06-20-2017, 08:26 AM
#540
Originally Posted by crod
As everyone else.
Type: 4462
Serial: X5021729
CDR-220 Radio
CR
Try 2310 first and if that doesn't work try 2299
Heiko
Previously owned:
