Old 06-14-2017, 06:05 AM   #534
Heiko
Heiko's Avatar
Originally Posted by madmac View Post
i couldn't get the display to give me the serial # i had to pull the stereo, it was stamped in the casing. does that make a difference?
As long as the logic board in the unit is still the original board its fine, but if that unit had a board replaced at one point the serial number will be different.
If you need the instructions again to retrieve the serial number here they are... it should work fine...
Turn off radio.
Hold down the TP button for at least 10 seconds.
Turn the radio on. "Becker 1" will be displayed.
Rotate the right knob slowly, as it will display the Becker model number.
Rotate again and radio serial number will display on radio display.
Heiko
Previously owned:
