Originally Posted by madmac
am i supposed to do anything other than just punch in these codes where the stars are? these put me in wait mode.
It should just run after entering the 4th digit.... if it goes into wait mode you've exceeded the amount of retries with the wrong code.
More times than not I've seen the display have issues and show wrong serial numbers.... I hope the serial w5009739 is the correct serial.... in which case the codes should work....
H
