Old 01-02-2020, 09:58 AM   #741
Heiko's Avatar
Originally Posted by david28121987 View Post
Hi Heiko
I just changed battery in my Boxster 2001 and My radio stop working, can you help me with that? I need radio code... Details:
Type: CDR 22
Model No.: BE 4467
Serial No. : 15036927
12 Volt EC 113
try 7032 first and if that fails use 7021
Heiko
Previously owned:
Old 01-02-2020, 02:08 PM   #742
C3s
Hi Heiko, can you help me please? I have the cdr220 in a 2002 986s which works great but randomly beeps at me, any ideas please?
Thanks,
Paul
C3s is offline   Reply With Quote
Old 01-03-2020, 10:19 AM   #743
Cheers Heiko, firts code make job... working again
david28121987 is offline   Reply With Quote
Old 01-04-2020, 08:24 PM   #744
Heiko's Avatar
Thanks,
Paul
you sure its not your speed limit alert that you accidentally set :-) that's usually the first question I ask people... Another thing to check is the connections on the faceplate... pull the faceplate off and get an alcohol pad and clean the little copper contacts - I've never actually seen these cause beeping noises but they cause all sorts of strange issues with the radio if the contacts are dirty.
H
Previously owned:
Old 01-08-2020, 02:54 PM   #745
C3s
Hello, thanks for your kind reply. I double checked the speed limiter and raised the speed, still more beeping. Both journeys today and no beeps so it’s completely random. The radio face plate has a small crack in the plastic, only visible when removed, also the first letter of the screen is pixelated so it reads ORSCHE no letter P
My son says that sometimes the radio screen says HOME or similar when beeping but l have never seen this as always driving.
Sorry to hijack the thread guys, this has been bugging me for aaaages.
Old 01-13-2020, 07:46 PM   #746
Heiko's Avatar
Might be time to look for a new faceplate or just a replacement head unit. Sounds like the faceplate could definitely have some damage which could cause this... Anyhow best of luck... I've seen these for sale on ebay but never actually changed one out.
H
Previously owned:
Old 01-29-2020, 05:30 PM   #747
Hi Heiko,
Would you mind looking up my radio code? Im a new owner and just found out about this issue.
Radio serial number is 25010600
Last edited by Rhtpt1263; 01-29-2020 at 05:54 PM. Reason: Didn't need to add vehicle vin. Sorry
Rhtpt1263 is offline   Reply With Quote
Old 01-29-2020, 05:52 PM   #748
I accidentally double posted, due to cell phone. Sorry
Old 02-11-2020, 07:56 PM   #749
Heiko's Avatar
Originally Posted by Rhtpt1263 View Post
Hi Heiko,
Not really an issue - its just that most people don't have the original code card :-)
4289 is your code :-)
Cheers
H
Previously owned:
Old 02-29-2020, 06:31 PM   #750
Hello All,
New to the forum and to Porsche.
I recently got a Boxster 2000 and need a radio code
CDR-220
Type 4462
S# Y5033707
Thanks in advance for the help.
richardfreeman812 is offline   Reply With Quote
Old 03-01-2020, 05:21 AM   #751
Heiko's Avatar
Originally Posted by richardfreeman812 View Post
Hello All,
CDR-220
Type 4462
S# Y5033707
Try 4585 first and if that doesn't work try 4575
Heiko
Previously owned:
Old 04-15-2020, 06:27 PM   #752
Looking for a code
To whom ever generates these code, thank you in advance.
CCR220
Sub model BE 6624
Serial 15002110
Thanks,
Curtis
Curtis729 is offline   Reply With Quote
Old 04-16-2020, 05:33 AM   #753
Heiko's Avatar
CCR220
Sub model BE 6624
Serial 15002110
Thanks,
Curtis
Try 0510 and if that doesn't work use 0500 but 0510 should work.
Heiko
Previously owned:
Old 04-19-2020, 04:42 PM   #754
dky
2000 Porsche Boxster Radio Code
Hello All,
I recently got a Boxster 2000 and would like some assistance with the radio code.
CDR-220
Model BE 4462
SN: X5035308
Thanks in advance for the help!
dky is offline   Reply With Quote
Old 04-29-2020, 05:27 AM   #755
Hello Everyone,
Can someone help me to find a code for both of my CDR-21 and CDR-22?
Serial numbers are the following:
CDR-21:T5005270
CDR-22:Y5023493
Thanks in advance!
Regards,
Berti
MantaMan is offline   Reply With Quote
Old 05-02-2020, 12:51 PM   #756
02 boxster radio code
Hi,
I need radio code for my boxster and hoping you guys can help me!
CR-220
BE 6624
15003109
Thank you! 🙏
Boxster1234 is offline   Reply With Quote
Old 05-02-2020, 02:00 PM   #757
Heiko,
Could you look up the code for my CDR-220.
Typ: CDR 220
Model: BE 4462
Serial #: 15086925
For two weeks I've been trying the number on the card in the radio manual, 4654, and it not being accepted, I removed the radio and it has a nice "Becker Replacement" sticker on the top...… now I know why 4654 doesn't work.
Thank you very much.
-Eric
Eric-986 is offline   Reply With Quote
Old 05-08-2020, 08:37 AM   #758
Lost CDR220 radio code
Hello all! I would appreciate some help. I can’t find my radio code:
2002 Boxster
CDR 220 radio BE 4462
Serial number 25014263
Thanks! PorterCP
portercp is offline   Reply With Quote
Old 05-12-2020, 07:30 PM   #759
Hello, I'm new to the site and looking for help. I haven't been able to find the radio code for the CDR-220 in my 1999 Boxster.
Type: 4462
Serial:W5005320
Any help is much appreciated.
Boxster1970 is offline   Reply With Quote
Old 05-15-2020, 08:21 AM   #760
Heiko's Avatar
Originally Posted by dky View Post
Hello All,
CDR-220
Model BE 4462
SN: X5035308
Sorry for the delay 9186 is your code
Heiko
Previously owned:
