Old 12-05-2005, 06:07 AM   #5
Sounds like overkill!!!!
Yikes!
160 watts pushing stock Porsche speakers???
Unless you keep the volume way low, you'll surely blow those babies.....I doubt the stock speakers can handle more than 40 w rms.....
My advice......Pull back on all those amps, improve the stock speakers, and get yourself 1 6 channel amp or 2 multi channel amps to handle things. Will be cheaper and more efficent, and will still sound a lot better in the long run.
1998 Guards Red Black/Black 5 sp.
Work done '06 :Replaced bad hose and clamps from reservoir tank
oil change and filter
replaced seals on both cam covers
brakes bled and refilled
Replaced bent rear right lower control arm
Front air dams and 3 underbody panels replaced
Halogen headlamps replaced
bigislandboxster is offline   Reply With Quote
