Old 11-29-2005, 04:36 AM   #1
Unhappy coolant finding its way to mix with engine oil?
My 2000 Boxster S's low coolant light flashes yesterday so I checked the coolant level in the back. It wasn't that low below the min level, but I ended up adding almost 2-3 quarts to the coolant tank to the mid level between min and max.
But today the warning light flashes back on and the coolant level is back down to yesterday's level again! The funny thing is my oil level(according to dip stick and electronic checking) both says the oil level is over the top! (the electronic gauge used to be at mid level, now is one bar over the top)
Does anyone have that issue? Perhaps coolant finding its way into mixing with oil? My 2-3 quarts of water ended up in the engine...
And does anyone knows what color is the coolant for 2000 boxster S made in Finland? my color is like brown which i think isn't right...
wonghoiman is offline   Reply With Quote
Old 11-29-2005, 05:59 AM   #2
Brucelee's Avatar
This sounds serious.
Take out the dipstick and put some of your oil on your fingers. If there is AF in the oil, the oil will feel and look differently than it does if it is uncontaminated. Usually, there is a greenish hue to AF but that differs by brand. Also, the AF has a slimey feel to it distinct from motor oil.
If you don't feel that you can discern this, drop by the dealer and they can do it in about 5 seconds.
I would caution you to do this immediately. There are only expensive fixes for this and the longer you wait, the more expensive they become.
Like, do it today and don't drive the car much until you rule out AF in the oil.
Hurry and let us know what you find.
Good luck.
Old 11-29-2005, 09:24 AM   #3
deliriousga's Avatar
Pull your trunk liner up in the rear trunk. I'll bet there's coolant under there and you have a cracked coolant reservoir. It's a leak that you can't see in the reservoir because it's on the back side so it leaks under the liner. The liner does not get wet showing the problem because there is styrofoam under it to help with engine heat.
If that's it and you want to DIY the job, let me know. I'll send you some instructions since I just did it in mine a few months ago. 4 hour job and ~$300.
1966 Wife White/Brown Top
Old 11-29-2005, 10:09 AM   #4
If coolant is indeed in the oil, do not drive the car. The AF will break down the oil very quickly and then you could ruine the engine.lll
If it's just the cracked coolant tank, no big deal and easy to change.
Richard
still don't have car back
my89_928gt is offline   Reply With Quote
Old 11-29-2005, 11:39 AM   #5
How many miles do you have?I would definetly not drive it till you have a handle on what's going on.Good luck and I hope it's nothing serious.
Frank
Frank is offline   Reply With Quote
Old 11-29-2005, 12:57 PM   #6
olly986
Guest
Posts: n/a
on the matter of coolant which is not really the issue here i will tell you what happen to by 2.5 boxster on track day, coming in after about 8 laps i cut the engine, as soon that it stopped a flow of coolant came splashing from below the engine, for this not to happen if you track your car let it idle a couple of minute before switching the engine off, as for coolant it is usually a little opaque/cloudy and taste sweetish, i know this won't help you with your problem and hope it is not too serious and you will be back motoring soon
