Pull your trunk liner up in the rear trunk. I'll bet there's coolant under there and you have a cracked coolant reservoir. It's a leak that you can't see in the reservoir because it's on the back side so it leaks under the liner. The liner does not get wet showing the problem because there is styrofoam under it to help with engine heat.
If that's it and you want to DIY the job, let me know. I'll send you some instructions since I just did it in mine a few months ago. 4 hour job and ~$300.
1966 Wife White/Brown Top
