on the matter of coolant which is not really the issue here i will tell you what happen to by 2.5 boxster on track day, coming in after about 8 laps i cut the engine, as soon that it stopped a flow of coolant came splashing from below the engine, for this not to happen if you track your car let it idle a couple of minute before switching the engine off, as for coolant it is usually a little opaque/cloudy and taste sweetish, i know this won't help you with your problem and hope it is not too serious and you will be back motoring soon
