Old 03-13-2013, 08:58 AM   #21
BYprodriver's Avatar
New tranny housing from Porsche.....$750.00
Tranny exchange from Porsche........$6600.00
New shift lever if shaft has wear......$407.00
When calling a few local trans shops two said they work on old & obsolete trannys all the time, and were sure they could size & replace the bearing since the outer seal is available. They said it's typical for some parts to not be available, and they match parts like that up by size and ream them to fit.
A few said Porsche???? Hell no!!!!!
All I gots to do is pull it!
Call Roger at California Motorsports in AZ after you checkout the website. Checkout the billet shift arrester & order that so you can install it while the tailhousing is off. It makes my trans shift better than it did when brand new.
