Old 03-08-2013, 03:40 PM   #1
I am my own mechanic....
Timco's Avatar
Rear shift-lever oil leak
Can these be fixed? I read that this means new trans housing, but find that difficult to believe.
Thanks.
'08 VW Touareg T-3 wife's car
Old 03-08-2013, 03:55 PM   #2
Mobile Porsche Surgeon
kashmir's Avatar
It sound like you went to a friendy porsche dealer, I'd get a second opinion from a good Indy garage.
Mike's Specialty Porsche Service
Mobile Mechanic Specializing in Porsche and Select Automobiles
http://www.mikesspecialtyautomotiveservice.com/index.html
Early 1996 / 97 Boxster, 130 k, De snorkeled, IMS, Top Speed Headers.
kashmir is offline   Reply With Quote
Old 03-08-2013, 09:24 PM   #3
Timco's Avatar
Do you work on these leaks? I'll ask around but there's only a couple import mechanics here I would trust with a Porsche.
Bummer!!
Old 03-08-2013, 10:59 PM   #4
Awesome.
The more I see this kind of stuff, the more I think either someone was asleep at the wheel over in German land or Porsche let the interns have a crack at designing a car when they decided to do the Box.
I've got this leak too and there is absolutely no way I'm replacing a transmission case to "fix" a pressed in bushing that someone thought was a legit idea to machine in place. Last time I checked, a bushing, by design, is a wear product. What were they thinking?!?
sam c. is offline   Reply With Quote
Old 03-08-2013, 11:05 PM   #5
The best picture I have right now. I guess I'm going to have to start looking for a solution (thats doesn't involve throwing away a perfectly good case)
Old 03-08-2013, 11:06 PM   #6
Old 03-08-2013, 04:11 PM   #7
The reason this type of leak is expensive to fix (requires a new tail housing unit) is because Porsche used a blank pressed in bronze plug in the side of the tailhousing that is then machined in place to accept the shaft. There are no aftermarket replacement bushings available, and machining out a new plug requires a lot of specialized tooling fixtures that you simply cannot buy.
Old 03-08-2013, 04:23 PM   #8
That's a bummer. I wonder if slathering the bushing with a heavy petroleum product like cosmoline might stem the tide a bit...
shadrach74 is offline   Reply With Quote
Old 03-08-2013, 06:41 PM   #9
Not really, they start to leak because the shaft has worn the bushing out of round, so smearing something over it will only slow it for a bit before it starts again. And because of the wear, shaft movement will only get it more out of round with time and use.
Fix it.
Old 03-09-2013, 09:08 AM   #10
BYprodriver's Avatar
Thanks.
If caught in time maybe a new bushing can be made.
Old 03-09-2013, 10:16 AM   #11
Problem is that the way the factory machines the bushing uses fixtures rather than the opening in the case to locate center of the shaft opening. Basically, Porsche designed the tailhousing to be tossed if the shaft starts to leak.
Old 03-09-2013, 04:06 PM   #12
Timco's Avatar
Anyone have a source for a new or rebuilt housing besides Pelican? It's a 6-speed.
Old 03-09-2013, 06:43 PM   #13
Spinnaker's Avatar
Sunset Porsche | Genuine Porsche Parts
Old 03-09-2013, 08:34 PM   #14
thom4782's Avatar
******************************************** is one and Jim Ellis another. You might give a dismantled or two a call - Oklahoma Foreign or DC Automotive
Old 03-13-2013, 06:08 AM   #15
Timco's Avatar
Just the facts.....
New tranny housing from Porsche.....$750.00
Tranny exchange from Porsche........$6600.00
New shift lever if shaft has wear......$407.00
When calling a few local trans shops two said they work on old & obsolete trannys all the time, and were sure they could size & replace the bearing since the outer seal is available. They said it's typical for some parts to not be available, and they match parts like that up by size and ream them to fit.
A few said Porsche???? Hell no!!!!!
All I gots to do is pull it!
Old 03-13-2013, 09:58 AM   #16
Call Roger at California Motorsports in AZ after you checkout the website. Checkout the billet shift arrester & order that so you can install it while the tailhousing is off. It makes my trans shift better than it did when brand new.
