12-14-2014, 05:04 AM
#21
Originally Posted by jim_hoyland
DRL ? What is DRL...
Daytime Running Lights.
12-14-2014, 09:58 AM
#22
Got a question:does the Spoiler Indicator Loght/switch both act as an up/down spoiler switch and an indicator light ?
Do I still need to install a separate spoiler switch into the dash console ?
12-14-2014, 12:14 PM
#24
Thanks. I did get the more expensive switch/combo. That's what I wanted.
12-31-2014, 08:26 AM
#25
I received the switch and instruction yesterday. I have two questions:
1) are the original wires that go to the fuse panel switch left unconnected ?
2) remembering the previous posts discussing the green wire, I want to know what to NOT do. The green wire has two pins; each hoes to a different slot in the connector. This seemed to be a problem area, please chime in and advise.
Otherwise, nice product, good instruction, and shipped fast; albeit came from Europe.
11-26-2015, 03:41 PM
#26
Problems...
I finally got around to installing the switch; there is a problem. Spoiler goes up and down correctly. The light in the switch stays on when the spoiler is up.
But; the switch light does not flash as the spoiler raises, but does flash when the turn signals are used.
Can anyone pinpoint the problem ?
11-26-2015, 05:21 PM
#27
Have one too....still have to install it. I had assumed that it would work correctly
986 00S
11-27-2015, 03:48 AM
#28
Where did you buy them ?
99 Boxster sold
88 944S sold
Xpit Formula Four sold
95 Integra Solo I sold
71 Opel GT sold
11-27-2015, 05:44 AM
#29
When I first installed mine, all of the lights flashed correctly while raising and lowering and stayed solid while it was up. However, when I installed the 996 cluster I lost the flashing while raising and lowering. It stays on solid while it is up and can still operate the spoiler manually. Based on what a PIA the wires are to deal with I have left it as is. The flashing lights were not that big of a deal. Having the solid light on is more important to me.
You do have an issue if the blinkers are causing the indicator to flash. I would betting a wire is plugged into the wrong slot of the plug.
Spoiler Control Indicator Switch Porsche Carrera Turbo 4S Boxster s 986 996 | eBay
1995 Porsche C4 Cab
11-27-2015, 06:26 AM
#30
Probably will be OK. Would you help me out when you do the installation ? After inserting the wires into the gauge cluster blocks, raise or lower the the spoiler and determine which wire transmits the flashing. Then I'll know which one of mine is in the wrong slot.
11-27-2015, 08:03 PM
#31
It will be a while before I can get to it.....spring as the car is all stored up. Not sure you would want to wait that long! It sounds like a real pain and am dreading it! Are the instructions wrong such that you cannot determine the right terminals?
The dude sent me an old crusty switch...which I have been trying to get replaced...no luck so far. I believe it is a just defroster switch with a sticker on it
986 00S
11-28-2015, 11:56 AM
#32
I read over the instruction several times, but ended up having my mechanic do the installation. It works fine; one of the wires got into the wrong slot and I believe it is the green wire.
Note:The two pins on the green wire are a real PITA; he installed two other connecting pins to replace them. I'll get the part name/number from him next week.
Doesn't matter at this point when I fix the flashing; just want someone who' scoring the install or working in that area to verify which wire/slot is hot when the spoiler is in operation. That would be the wir/slot I have wrong.
11-28-2015, 02:51 PM
#33
Okay, yes some more robust pins on those wires would be good.... so much appreciated. They look like they will break or bend on the first try
986 00S
11-28-2015, 03:21 PM
#34
Does anyone have a picture of the pin to use on the back of the instrument cluster?
11-30-2015, 04:41 AM
#35
Update of sorts...
OK; I've used this several times now and found that it flashes when going up ( can't detect any flashing when retracting). Still flashes when turn signal used. Not sure the footwell switch is working, gotta test it more. I'll stop by the shop today and find out the part # for the grenn wire pin replacements.
12-18-2018, 02:51 PM
#36
I have just installed this now on a 2000S.....It was bit dim as far as lighting goes here in the north but got it in there. Unfortunately, I have no indication when I actuate the spoiler ....even with the original switch. This the test during first phase of the installation.
I went over instructions in English and in French on the internet and still no joy.
Some notes:
-some the pin connectors are fairly loose fitting going into the cluster harness terminal blocks.
-there were two brown blue wires in one cluster plug so I just picked one.
-some of the wires had similar colour under LED lighting...but I think I got It right
-the green wire with double prongs appear to go as far as it could in the appropriate terminal block but the prongs are quite long don't look like they can go all the way in. I have exposed prongs.....on a 97-01 type terminal block.
Did any experience this on install? If so what wiring strategy fixed it?
My next step is to test with another switch if I can...
If any need pictures of these components exposed please let me know....while I have everything apart; before I head out west again!
P.S. did I mention that I hate electrical wiring work!
986 00S
12-18-2018, 04:03 PM
#37
There Is No Substitute.
Mine shows when the spoiler is deployed (solid light) and when it is going down (flashing), it does not flash when the spoiler is deployed. This is because I broke the pin that you insert into the cluster plug, which I am pretty sure is actually the end of a diode. I just accepted it and moved on, but if it bothers you, I would make sure the pins are all inserted well.
he switch has nothing to do with the indicator light, the switch only controls the actually spoiler deployment/retraction, and the switch is not even used when the spoiler deploys automatically.
12-18-2018, 04:11 PM
#38
....oh I am not getting any indication at all with the car stationary
986 00S
12-18-2018, 04:28 PM
#39
I thought you only had an issue with the light when the spoiler went up. The indicator should work when stationary.
I would check to make sure the pins are inserted in the correct slots, you could also try reaching out to the ebay seller, I have communicated with him before and he seemed helpful.
12-19-2018, 02:53 PM
#40
986 00S
