Originally Posted by jim_hoyland
Got a question:does the Spoiler Indicator Loght/switch both act as an up/down spoiler switch and an indicator light ?
Do I still need to install a separate spoiler switch into the dash console ?
Depends on which switch you buy. The cheaper switch just lights up to indicate the movement of the spoiler. The more expensive switch lights up to indicate the movement of the spoiler and you can use the switch to raise and lower the spoiler.
My Boxster has a switch at the fuse panel cover from factory that will allow you to manually raise and lower the spoiler. You could use that switch and just buy the cheap switch that only indicates the movement of the spoiler.
Cheaper switch that only indicates the movement of the spoiler.
http://www.ebay.com/itm/SPOILER-CONTROL-INDICATOR-Porsche-Boxster-S-986-996-TOP-/261669778881?hash=item3cecbbf5c1&vxp=mtr
More expensive switch lights up to indicate the movement of the spoiler and you can use the switch to raise and lower the spoiler.
http://www.ebay.com/itm/Spoiler-control-indicator-switch-Porsche-Carrera-turbo-4S-Boxster-S-986-996-/261698591779?hash=item3cee739c23&vxp=mtr
